Stuttering power mirrors (reverse)
Old Dec 9, 2009 | 05:38 PM
TLTrance's Avatar
AVB for President!
Exclamation Stuttering power mirrors (reverse)
How many of you have the "stuttering" power mirror issue where the mirror (left or right side) will have difficulties moving up or back down after putting the car in reverse and then out of reverse (like drive or park)? Sometimes it will also get "stuck" after trying to move up or down.
I've always had this issue and it seems that it comes and goes. I recall that there was a recent service bulletin about this, although I'm not sure if this would address my issue...
I have a 2005 5AT TL.
Old Dec 9, 2009 | 05:39 PM
gotkilled's Avatar
NBP is a pain...
this happens on my tl as well. i'm fine with it though. the stuttering doesn't bother me as it doesn't get stuck. It's just that the motion isn't fluid/smooth.
Old Dec 9, 2009 | 05:40 PM
TLTrance's Avatar
AVB for President!
Mine gets stuck and it ultimately does not make it back to the "original" position...
Old Dec 9, 2009 | 05:45 PM
JwongTLS's Avatar
https://acurazine.com/forums/3g-tl-problems-fixes-114/replace-side-mirror-actuator-motor-755014/
Old Dec 10, 2009 | 12:12 AM
TLTrance's Avatar
AVB for President!
Thanks! I guess since I'm still under warranty I should just bring it in... Got to get some other stuff looked anyway..!
Old Dec 10, 2009 | 09:36 AM
Waveform's Avatar
'06 NBP TL 5AT NAV
This is the second go 'round for my '06. I had both of the mirrors replace under warranty two years ago and now the drivers side is at it again. I'm still under warranty, so no worries.
My service advisor states that they are just replacing the actuator, not the entire mirror assembly as before.
Old Dec 10, 2009 | 12:20 PM
the-carbon-comet's Avatar
Full A-Spec 08 CBP TL-S
Take it in, I got my driver side mirror replaced due to the same problem you were having. Had a rattle coming from that mirror as well so it killed 2 birds with one stone.
Old Nov 9, 2010 | 02:32 PM
scv76's Avatar
Just had both actuators replaced this last week under warrantee.
Everything now works as it should.
I questioned the dealer if possibly the replacement actuators had any design changes made since the originals were produced. He said no changes....so we should probably expect the problem to show itself again in the future.
Old Nov 12, 2010 | 11:09 PM
TLMunchkin37's Avatar
I've had this issue a few times as well; it seems to correct itself if while in reverse during the "stutter", I switch it from Driver to Passenger and then back to Driver (which I keep it on normally)
It seems to correct and suddenly come out of it's stutter. I should bring it in...just another reason for the dealership to hate me!
Old Nov 13, 2010 | 06:15 PM
Whdrms's Avatar
e92TL
It seems like mine does that too sometimes... But doesnt bother me much :p
Old Nov 13, 2010 | 08:57 PM
VQPower37's Avatar
mine duz it as well ... out of warranty so im gunna run it til i have to replace it
Old Nov 14, 2010 | 01:24 PM
U3A6's Avatar
Have an 06 and occasionally the mirror stutters. Tech at the dealership says to occasionally hose out the mirror with a "light" stream of water. If you live in a area that gets leaves or you park it outside all sorts of stuff gets behind the mirrors. Crap fouling the plastic actuator gear causes wear and the stuttering (which is actuator gear slipping).
The TSB for the mirrors addresses an issue where the plastic actuator gears get worn or stripped. Early on, they used to replace the affected mirror, now they just replace the actuator.
Tech told me that occasionally operating the mirror full up, then full down, full left, and full right can move the gear enough to find a good spot. When I do this-there is a definite "click" when the gear slips and catches on a good spot. Fixes it for a little while.
Old Nov 14, 2010 | 02:11 PM
Andy Tsang's Avatar
I've done the same as the above but its starting to stutter again....
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
STC
Sep 23, 2015 04:36 PM
