Stripped thread for Throttle Body Bolt
Old May 19, 2008 | 08:27 PM
t0talacuratl's Avatar
Green Machine
I really did it this time! I was cleaning my throttle body the other day. After putting everything back together, I couldn't get one of the throttle body bolts to tighten. The other three bolts are tighten to specs (16 ft/lb). How can I fix this without having to replaced an expensive intake manifold?
Old May 19, 2008 | 09:14 PM
lars161's Avatar
Timesert thread insert.
If you are near a napa autoparts store they should have them
or check around at auto parts store
what it does is you drill the whole out bigger then you tap that out with a backwards thread and then a piece threads into that where you then can put your bolt into that
Old May 19, 2008 | 10:04 PM
01tl4tl's Avatar
if the threads are lightly trashed - which will require removal of the TB assembly to see whats up- trashed but still there-
you have the possibilty of using a thread tap to recut the threads in the same original way.
If they look torn or destroyed- then the insert described in other post- is the way to go.
You drill a larger hole toremove the remainder of the threads- put the ~spacer with replacement threads~ in the new hole and put it all back together.
Get a ride to parts store, with pics of whats going on, and take the offending bolt and a good bolt for the person to help you get the right stuff
Good luck-- and next time bring the torque down even on each bolt a little at a time- 16 ft lbs is not very much at all-
allways check your torque wrench calibration first,,, by testing what the bolts are at before removal~
Failure to keep torque wrench (spring activated click type) stored with light- 10 pounds pressure on them will result in screwy readings all the time. a tip from snap-on tools!
Old May 19, 2008 | 10:56 PM
Green Machine
Thanks for all the info guys! I'm just glad it is a simple fix.
Old May 19, 2008 | 11:29 PM
Doc's TL-S's Avatar
BLUE SMOKE
Things just sometimes do not go the way we planned, do they? Happens to me all the time, except not my TL-S. Hope you get if fixed Adrian.
Old May 20, 2008 | 12:22 PM
Green Machine
Thanks Dave! I'm just waiting for my clutch to go out next. Oops, knock on wood!
Old May 24, 2008 | 05:33 AM
Green Machine
Fixed the problem with amazing results!
Well after taking it to my favorite local shop, because I didn't want to screw something up worst. They figured out that I only needed longer bolts than the ones that come with the P2R spacers. They only charged me $10 (cost of the bolts).
I may be crazy, but I think I gained about 10hp/10tq. Reason, I had the pro-cats put on right after I installed the P2R. I only gained 8hp/2tq, which was puzzling with the pro-cats reputation. Those bolts were the missing link. My car has mad power now! Needless to say, I will be doing another dyno very soon!
Old May 24, 2008 | 12:57 PM
01tl4tl's Avatar
Let Excelerate know they spacer didnt come with the proper bolts.
Maybe your bag got left out at the maker and he can let them know
I dont know about P2R, but the other theroblock brand comes with all the bolts you need to replace the tb and 2 bolts in the intake manifold !!
Old May 24, 2008 | 02:39 PM
Green Machine
Now that I think about it, I don't think it was the bolts that came with the spacers. I could have screwed up the thread pattern during the original install. I've taken it apart a few times for other reasons as well, so that could have contribute to it. Besides I haven't heard of anyone else having this problem with the kit. But I will pm Josh just to let him know. Thanks!
Old May 24, 2008 | 08:54 PM
Bearcat94's Avatar
AZ Community Team
Mine came with new bolts. You *gotta* have new bolts because the spacer adds almost an inch in length.
Old May 24, 2008 | 10:17 PM
Green Machine
I got the new bolts as well.
cycdaniel
Dec 17, 2019 10:58 AM
ryanfett
Oct 29, 2015 06:01 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
EvilVirus
Aug 31, 2015 05:24 PM
