Steering Wheel Wobble
Old Jun 11, 2008 | 10:28 AM
KylesTL's Avatar
I just got back from a trip and on the way back I was noticing that light braking at highway speeds my wheel wobbled(i just like that word and it's a good description) back and forth until I either broke harder or let off.
The tire pressure seemed fine although I have to check it again when I leave to get a better cold pressure reading.
I did get new tires, exact same OEM Michelin's that came on the car. I'm thinking the place that did it didn't balance them properly. Don't want to go back there though, if anything I'll bring it to Acura
Any input on anything else I should check before I make that call over to the dealer to check my alignment and balance?
Old Jun 11, 2008 | 11:13 AM
Will Y.'s Avatar
Registered but harmless
It sounds like it could be slightly warped brake discs/rotors if it only happens under braking. If it's slight warpage and the rotors are thick enough, turning/machining them should fix it. Otherwise, new rotors will be necessary.
Time to get new brake pads?
Old Jun 11, 2008 | 11:46 AM
Tripnbeats's Avatar
yes cut the rotors or get em changed if they are below spec
Old Jun 11, 2008 | 01:02 PM
KylesTL's Avatar
I actually just brought it to the dealer before I left and said check the brakes. Of course it was no problem plenty of life left and all that. I'm defineley thinking I'm going to go back to the dealer and let them check it out. I still don't trust my tire guy either he's a little shady.
Actually someone just told me the strangest thing, same problem and in the end the issue was that the lug nuts were overtightened. I'm still trying to work that one out in my head
Old Jun 11, 2008 | 02:30 PM
ecliptics's Avatar
steeez
i've heard shakey steering wheel = your shocks/struts, how many miles do you have on the car?
i'm not sure if its the same cause shaking under breaking only though.
Old Jun 11, 2008 | 02:35 PM
bryanlee81's Avatar
TL-S Addict
if the shaking is happening all the time, then it's balancing issue.
If the steering is shaking only when you are braking, then it's 99.9% warped rotor issue.
If the shaking is moderate, then you can just grind the rotors, but if the shaking is pretty bad, then you have to replace the rotors.
When you replace the rotor, make sure you also replace the pad as well. Used pad that has been used with the warped rotors will cause warping again on the new rotors.
Old Jun 11, 2008 | 02:57 PM
ecliptics's Avatar
steeez
what do you mean you can just grind the rotors with moderate shaking?
Old Jun 12, 2008 | 09:31 AM
Tripnbeats's Avatar
ecliptics where do u get bad shocks making ur wheel wobble??? i hope not a mechanic u go to.
Old Jun 17, 2008 | 03:06 PM
tng812's Avatar
9th Gear
Mine shakes when i am going over 65 mph no braking involved. any ideas?
Old Jun 17, 2008 | 03:54 PM
Will Y.'s Avatar
Bad wheel balance for whatever reason- get car's wheels balanced unless the tire wear is uneven (in which case, get new tires balanced).
Old Jun 17, 2008 | 09:01 PM
TheBster's Avatar
Just Win Baby
It sounds like you will need the rotors checked - resurfaced, turned, or replaced.
Get new pads if you get new rotors.
Old Jun 20, 2008 | 07:51 PM
04 TL 04's Avatar
i have the same problem, it increases when the breaks get warmer
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
EvilVirus
Dec 10, 2015 07:38 PM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
