Steam from exhaust.
Old Dec 6, 2015 | 09:22 AM
lians60's Avatar
Steam from exhaust.
My TL has consistent steam coming from the exhaust. It is getting cooler here in NY but has been pretty mild thus far 40-50 degrees. I understand that condensation is normal but it seems that mine is pretty consistent and will continue even after a 20 minute drive.
The car does not overheat. The coolant levels are good. The oil seems to be good, not milky. The steam coming out of the exhaust smells like steam, not sweet or anything like that.
When examining the muffler I did notice quite a lot of water in the actual muffler. It's not flooded by any means but a thin sheen of water inside. I've attached a picture and video for reference. I'm just paranoid and hope its not a blown head gasket. Thanks in advance!
Old Dec 6, 2015 | 06:53 PM
MarcDavidoff's Avatar
Interesting but looks normal in the video. Coolant smoke would be thicker and wouldn't dissipate so soon
Old Dec 6, 2015 | 11:16 PM
truonghthe's Avatar
mine TL does that too even in 50-60 degree but then again, I regularly wash my exhaust tip and spray them down with water.
Old Dec 6, 2015 | 11:21 PM
TacoBello's Avatar
You're not serious, are you?
Old Dec 7, 2015 | 06:47 AM
OP, Dont forget to:
Old Dec 7, 2015 | 12:45 PM
truonghthe's Avatar
Justin one of my friend works for Audi of Silver Spring in MD as a services advisor send me a pic earlier the document read "Customer complaint brake pedal feel spongy car become hard to stop, customer stated saw on facebook add coolant into break fluid to prevent the fluid being freeze during winter" Dam someone actually felt for it.
Old Dec 7, 2015 | 12:55 PM
thegipper's Avatar
Looks perfectly normal to me....
Old Dec 7, 2015 | 02:45 PM
Vlad_Type_S's Avatar
Registered Bike Offender
Lol. Relevant anecdote: So, the RV6 true duals actually use several separate pieces of pipe which are held together with clamps. Since they're clamped, it's not a perfect seal. So, if I leave my car running in one spot and then look underneath the car, there will be water dripping from the exhaust joints where the clamps are.
This is normal, from what I can tell. If it's not normal, then my car and yours have the same problem lol.
Old Dec 7, 2015 | 02:50 PM
TacoBello's Avatar
Has no one ever had their car outside when it's cool? It's 198% normal. Spacecadet knows what's up.
Old Dec 7, 2015 | 03:08 PM
lians60's Avatar
Thanks everyone. Sorry for being a paranoid noob. Cheers.
Old Dec 7, 2015 | 05:05 PM
6MTSSR's Avatar
Yes mine does the same ..here in the northeast with the 50-60 degree weather in December I see every car in front of me doing the same.Stopped at a light get on the gas and a stream of water sprays slightly out of the exhaust.Its called condensation!
Old Dec 10, 2015 | 09:56 AM
aIRpeACE's Avatar
it's normal. nothing to worry about
NetGnome
Apr 24, 2017 02:33 PM
Superclaudio
Dec 12, 2015 01:42 AM
GaRaS
Dec 6, 2015 09:13 AM
bigcocoon
Dec 5, 2015 09:32 PM
eaglesfan398
Dec 5, 2015 04:57 PM
