Starting issue!
Old Dec 30, 2020 | 06:12 PM
DatboiDennis's Avatar
08 WDP TL
Starting issue!
Hey everyone!
would like to get some help finding out the problem recently came up (please see video). It never happens in the morning, only after I get to work or wherever and let it sit for a couple hours.
File Type: mov
Old Dec 30, 2020 | 06:16 PM
the starter perhaps?
Old Dec 30, 2020 | 06:38 PM
08 WDP TL
I was thinking it might be starter, ignition switch, or fuel pump/fuel injector. But didn't want to start just start buying stuff and hoping that would be the cause
Old Dec 31, 2020 | 07:52 AM
nats007's Avatar
I can't see the video, but I've have had intermittent starting issues with my TL and been ruling out issues slowly. Only recommendation is to try and pinpoint the issue.
My starter was tested first and that was good. Then, I checked all fuses and relays and confirmed those were good. I hear the fuel pump prime when the key turns, so I believe that is OK. I got on the internet and searched my issue and it's gotten me to check the transmission range switch as potentially failing. That's next on the list to change (already have the part).
Hope you figure it out!
Old Jan 2, 2021 | 08:04 AM
DMZ's Avatar
DMZ
Head a da Family
Have you checked the + battery cable? At this age, it could easily be corroded internally where you can't see an unable to carry enough juice to turn the starter.
Old Jan 2, 2021 | 08:24 AM
also grounds...check the grounds.
Old Jan 3, 2021 | 09:13 PM
nats007's Avatar
Good tip! I need to check mine as well.
Agreed for negative as well. I believe I checked my ground cable, but did not think about the positive cable.
Old Jan 5, 2021 | 07:22 AM
DMZ's Avatar
DMZ
Head a da Family
The + cable is the one that carries the juice to the starter and the rest of the car! DUH............
mark101010
3G RDX (2019+)
Dec 30, 2020 05:33 PM
Big Dom
Integra
Jan 30, 2020 03:29 PM
Netspeed
Mar 10, 2018 10:54 PM
Faded_TSX
1G TSX Problems & Fixes
Jun 5, 2015 09:23 AM
kbh
14
Sep 10, 2014 07:09 PM
