Squeal from brakes..
ib4planeoverhead
Love Guru
Dealer is just making a fool out of you..... You can easily go another 50K miles with these... if not more.... I know you wont believe this, but the dealer is trying to steal your money.... those stealers....
Honestly, I'd check the inside pad and rotor for wear. Looks fine otherwise.
BANNED
derp.
takin care of Business in
Received 4,732 Likes
did you make sure your blinker fluid is topped off ???
Undying Dreams (09-14-2012)
NOOO
the one from Autozone only works on V8 engines...the one which you want for our cars is a semi synthetic formula....it gets rid of any squeaks in our cars...you will get that at Home Depot...
also check their website out, squeakfarkoff dot com
If its squeaking you can always get a good high temp brake grease and spread it evenly across the rotor surface. That'll stop the squeaks. Just be sure not to put it one too thick or it will build up on the pads.
lol the noises are probably just in your head. Like stated before, I would just check for uneven pad wear while your in there. Just to be safe use a semi synthetic lube/or bearing grease on your rotors just incase they are squeeking. Literally smear it on until its totally covered, always works for me.
Slot Machine Lubricator
Hmm, Acurazine to have its own /r/shittyadvice.
We have a couple of cadets on deck.
