Squeaky Belt
Old May 22, 2009 | 08:56 PM
madcaps's Avatar
Lt. Gamble
Squeaky Belt
First off I want to say that I tried searching for a solution to this problem beforehand but the search sucks so I started this thread. So, today I'm driving home from work and my car begins to squeak under the hood and the squeak gets louder the more I push on the gas. I'm assuming its the serpentine belt(?) or something like that. Can someone confirm this and possibly give me a price on what it will cost to fix this issue, thanks for your help!
Old May 22, 2009 | 09:07 PM
TLAdvanced's Avatar
The Kinetics of Bleu
It could also be a bearing going bad on idler pulley or something like that. It is kind of hard to determine by the vague description.
Old May 22, 2009 | 09:22 PM
madcaps's Avatar
Lt. Gamble
Well...hmmm...I really can't explain it any better. I'm familiar with the sound a belt makes when its going bad and it is making a similar sound, squeak gets louder the more I push on the gas and when I let up on the gas the squeak slowly goes away. I guess I'll just have to make an appointment with my local dealership to figure it out. Thanks.
Old May 24, 2009 | 11:21 PM
vegas tls's Avatar
may want to check with the dealer. i just got my oil changed friday and the service advisor who i had been dealing with for the last few year told me there a new service recall on the belt so is under warranty.
Old May 25, 2009 | 09:05 AM
vinnier6's Avatar
you can replace your s belt in less then 5 minutes, the belt is like 50 bucks, get the gates one.....
Old May 25, 2009 | 08:30 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
where do you buy the belt? stock size gates or other best one out there?
Old May 25, 2009 | 08:44 PM
el.profe's Avatar
its the belt.. i changed mine not too long ago. its a wear and tear, its not under warranty.. cheaper to pay a mechanic or diy. dont do it at an acura dealer
Old May 29, 2009 | 11:00 PM
mrlunecy's Avatar
312 HP 271 TQ Dynapack
gates sucks, personally. I had one for 1k mi. before it started squealing bloody murder. then I chucked it. Goodyear Gatorback for the win. they're pretty much in every autozone or kragen, etc. I'm sure they make the right size for the TL, but I'm supercharged so I never used a stock size replacement.
i think they're like 25 bucks? I forget. i think 50 is too much
replacing it is cake. they make a tensioner pulley rod just for replacing serpentines. makes it a lot easier. probably be cheaper buying it than having it done by a mech...plus you get to add a new tool to your collection!!! but you can also make due with a long handled ratchet. I've replaced/swapped belts on my TL a bunch of times.
Old May 30, 2009 | 03:27 AM
madcaps's Avatar
Lt. Gamble
Does the TL only use one belt to drive the motor, power steering, A/C, etc. or are there individual belts for each of these components? The reason why I'm asking is that I think the squeaking may be a caused by the A/C because I had my car parked while running the A/C and you could hear a faint squeaking sound. Also, when I checked it with the A/C turned off the squeak got even quieter. I know a real good honda mechanic that I'm going to take it too, probably will be a lot cheaper than going to a stealership. Thanks for the info!
Old May 30, 2009 | 11:47 AM
mrlunecy's Avatar
^ just one belt. when the a\c clutch kicks on, it puts a bigger load on the crank and causes the tension to shake, causing the squeak to change pitch or get louder/quieter. Still a chance it could be a bearing, but chances are...it's the belt. I would start there since it's a snap to change it out.
Old May 30, 2009 | 06:58 PM
madcaps's Avatar
Lt. Gamble
Cool, thanks for the help!
Old May 30, 2009 | 07:35 PM
BlacuraTL-S's Avatar
NBP REPRESENT
im having the exact same problem...
got an appt for dealer on monday...they are doing some other warrnty work so im going to try to get them to change it or something
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
