Spooling Noise on Acceleration
Old Feb 22, 2014 | 10:41 PM
The Sarge's Avatar
When accelerating my auto tl makes a spooling noise. Almost sounds like a turbo spooling but not turbo here
Any suggestions on what it could be?
Old Feb 22, 2014 | 11:31 PM
paperboy42190's Avatar
transmission whine?
Old Feb 23, 2014 | 12:12 AM
The Sarge's Avatar
Yeah could possibly be trans. anyone have anything similar to this noise? Is it normal?
Old Feb 24, 2014 | 09:27 PM
Jesse729's Avatar
Power steering pump? Does it happen when it is cold? Did you ever have the o-ring on the power steering pump replaced?
Old Feb 24, 2014 | 09:47 PM
Alexns05's Avatar
What is a spooling noise? Is it exacerbated by the turning of the steering wheel? If so it's the power steering
Old Feb 24, 2014 | 09:53 PM
The Sarge's Avatar
its not the powering steering. it accelerates with engine rpm. Power steering not making noise or problems turning. I believe its something else.
Old Feb 25, 2014 | 08:44 AM
07GSXRStretched's Avatar
4th Gear
My 02 Type S also does the same thing...I believe its tranny noise
Old Feb 25, 2014 | 08:50 AM
Coins's Avatar
My car makes a noise on acceleration as well.
I hear it at around 35-40+ when I lightly press on the accelerator but when I lift off it goes away
I just had my transmission replaced but I took it back to get the noise checked out.
Travis thinks it's the differential in the transmission.
Old Feb 25, 2014 | 07:44 PM
3RDGENTL757's Avatar
If it sounds like a turbo sucking in air then Have you or had a shop recently replaced your air filter? Kinda sounds like the top your air box isn't tightened down or the box or intake tube has a big hole in it. If never here'd of a tranny making a noise that sounds like turbo spooling...take a video with sound and post it up that would make it a lot easier to point you in the right direction
Old Feb 25, 2014 | 10:58 PM
ultimatum127's Avatar
It might be low steering fluid. Just check to make sure you arent running low.
Old Mar 4, 2014 | 08:05 AM
Lechip's Avatar
7th Gear
mine does the same thing, it does sound like a turbo. It has done it for about a year or so. (08TL 69K mi)
Old Mar 5, 2014 | 01:12 PM
cam_2's Avatar
When accelerating, mine makes a sound like a turbine spooling up, like a jet engine or helicopter. I like this part of the aural experience . It has to be from the transmission, because iirc its frequency changes with gear shifts.
Old Mar 5, 2014 | 08:35 PM
Anonymous95's Avatar
3rd Gear
Mine as well...hmmm good to know
Old Mar 5, 2014 | 11:26 PM
guitarplayer16's Avatar
My TL has been making the same sound, ever since I can remember.
Old Mar 14, 2014 | 04:03 PM
JesseDean's Avatar
9th Gear
My tranny makes a kind of whistle. I have been in 2 others that do the same. Mechanic said tranny. Its normal
Old Mar 21, 2014 | 09:06 PM
Due_Diligence's Avatar
Mine does the same, I read somewhere that replacing the ATF can reduce the noise.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Mike734
Dec 10, 2021 01:25 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
copmagnet82
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
