Small Puddle of Clear Liquid on the Floor, Possible Leak?
Old Mar 4, 2006 | 10:42 PM
datmrman's Avatar
Question Small Puddle of Clear Liquid on the Floor, Possible Leak?
Hi all,
This started maybe about 3 weeks ago. Each morning when I pull out of my garage, I've noticed a small puddle of clear liquid on the garage floor. Am I correct to assume that this is AC related and there is really no cause for concern?
The car is about 10 weeks old with 3500 miles on it. No maintenance has been performed on it yet. I leave the AC on auto all the time. Anyone else noticing this? Thanks for the replies.
Old Mar 4, 2006 | 10:50 PM
JoganJani's Avatar
never stops!
If it is clear like water then indeed it is AC coil water.
Old Mar 4, 2006 | 11:19 PM
Will Y.'s Avatar
Registered but harmless
Condensation probably
Your initial impression is likely correct (hopefully!). If your A/C has been running for more than a few minutes, there will be condensation dripping onto the floor. You will notice this occuring everywhere you park; just look under the car after returning from a short errand of a few minutes. On a sloped parking space, the condensation will run downhill in a little stream.
Otherwise, if you have doubts, stick your finger in it and smell to confirm it is plain water, as opposed to leaking antifreeze, brake fluid, oil, transmission fluid, etc. Then check all fluid levels.
Old Mar 5, 2006 | 12:00 AM
subinf's Avatar
One on the right for me
i always have a shitload of AC water under my car. at first i thought it was too much but its all normal.
Old Mar 6, 2006 | 10:18 PM
datmrman's Avatar
Thanks all! Now this raises a new question. So the liquid is coming from somewhere (condensation on the coil) due to the AC.. so other than freon to keep the AC cool, is there anything else that needs to be refilled from time to time in order for the AC to work?
Old Mar 7, 2006 | 02:01 PM
massr1's Avatar
The condensation that accumulates on the coil comes from the moisture in the air; don't worry mother nature does the filling
HairyMonkey019
Apr 22, 2016 10:50 PM
BoricuaTL
Apr 8, 2016 01:08 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
thegipper
Oct 21, 2015 07:19 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
