Small Puddle of Clear Liquid on the Floor, Possible Leak?
Hi all,
This started maybe about 3 weeks ago. Each morning when I pull out of my garage, I've noticed a small puddle of clear liquid on the garage floor. Am I correct to assume that this is AC related and there is really no cause for concern?
The car is about 10 weeks old with 3500 miles on it. No maintenance has been performed on it yet. I leave the AC on auto all the time. Anyone else noticing this? Thanks for the replies.
Condensation probably
Originally Posted by JoganJani
If it is clear like water then indeed it is AC coil water.
Otherwise, if you have doubts, stick your finger in it and smell to confirm it is plain water, as opposed to leaking antifreeze, brake fluid, oil, transmission fluid, etc. Then check all fluid levels.
Thanks all! Now this raises a new question. So the liquid is coming from somewhere (condensation on the coil) due to the AC.. so other than freon to keep the AC cool, is there anything else that needs to be refilled from time to time in order for the AC to work?
BoricuaTL
Apr 8, 2016 01:08 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
