Slow Starting
Old Jun 30, 2020 | 06:09 AM
DMZ's Avatar
DMZ
Head a da Family
Slow Starting
Last few days, it takes unusually long for the engine to turn over when I turn the key. I have plenty of cranking power and no problems after it does start. Could it be bad gas (from Costco), starter beginning to go after 328K miles?
Old Jun 30, 2020 | 07:23 AM
Ted Kief's Avatar
Check the battery cables and connections
Old Jun 30, 2020 | 07:37 AM
DMZ's Avatar
DMZ
Head a da Family
Connections are tight. The battery is about 1 year old and the battery cables are about 3 years old.
Next .............
Old Jun 30, 2020 | 09:11 AM
Jackass's Avatar
Can you elaborate on this?
It takes unusually long:
- before the starter engages after you turn the key?
- before the engine actually fires and starts? (long cranking time before ignition)
- the starter/engine is turning very slowly? (starter struggling to turn the engine)
Old Jun 30, 2020 | 10:13 AM
DMZ's Avatar
DMZ
Head a da Family
A - before the starter engages after you turn the key?
B - before the engine actually fires and starts? (long cranking time before ignition)
C - the starter/engine is turning very slowly? (starter struggling to turn the engine)
Answer: B - before the engine actually fires and starts
Old Jun 30, 2020 | 12:14 PM
Jackass's Avatar
So in theory, that would be spark or fuel challenges. Does this behavior change on cold vs warm starts? Is the behavior any different if the car was running, turned off, and immediately restarted? Wondering if your fuel pump isn't priming the system up on cold start? I'm off on a guessing game here....I haven't had to chase this issue myself.
Old Jun 30, 2020 | 12:44 PM
horseshoez's Avatar
Latent car nut
Yeah, I'm thinking a fuel issue as well.
Old Jul 1, 2020 | 06:35 AM
DMZ's Avatar
DMZ
Head a da Family
Paul checked it out yesterday. His prognosis, the fuel pump. I guess after 16 years and 328K miles.........
The replacement has been ordered from rockauto and will be here tomorrow.
Old Jul 1, 2020 | 07:36 AM
t-rd's Avatar
Most likely fuel pressure regulator integrated into the fuel pump can in the tank.
If you keep the key in position II for a few seconds to let the fuel pressure build up, then go to crank and it starts immediately, then that's it.
Old Jul 3, 2020 | 07:38 AM
DMZ's Avatar
DMZ
Head a da Family
Paul sez at this age and mileage, replace the whole assembly with the float which I can understand. That's what I'm doing today
Funny though, the price at rockauto went up $40 for the exact same Spectra Premium pump assembly the day after I ordered it!
Anyone else notice how prices are going up on almost everything these days, including gas?
Old Jul 3, 2020 | 08:17 AM
horseshoez's Avatar
Latent car nut
I've been in work from home mode since March and have only filled up once since mid-March, and that was for only a $1.25 per gallon.
Old Jul 3, 2020 | 10:40 AM
DMZ's Avatar
DMZ
Head a da Family
But that was then and this is now! $1.25/gal? Where the hell do you live, outer Mongolia? Costco premium is $2.49/gal after being $2.19 just a couple of weeks ago. Inflation in this country is back with a vengeance, and no notice of it on the newz! Just like unemployment is 11.9%, HA! Anyone dumb enough to believe that ................
neverender158
Nov 26, 2020 03:25 PM
DMZ
Nov 5, 2018 03:24 PM
BigJLM1
Apr 20, 2014 12:49 AM
Akim711
2G CL Problems & Fixes
Jul 23, 2008 02:49 AM
speedzer
1G TSX Problems & Fixes
Aug 4, 2003 03:02 PM
