Slow 3 to 4 shift on AT (2005 TL)
Old Sep 30, 2012 | 07:28 PM
AbyssPearlTL's Avatar
I'm having an issue with a slow engaging 3 to 4 shift when driving slowly. I have replaced the pressure switches about 10k ago. I was thinking it might be them again. Which switch controls the 3 to 4 shift? Also, I'm using redline ATF type f
Old Sep 30, 2012 | 08:06 PM
kingkong_dav's Avatar
KingKong_Dav
your trans is BURNING, n Slippping! thank redline for it. i warn so many members to stay away from redline because it contain no friction modifiers that honda acura needs.
Old Sep 30, 2012 | 08:23 PM
no. sad that the best acurazine has to offer is a troll.
Old Sep 30, 2012 | 09:35 PM
KingKong_Dav
its ok.. i tried to tell u.
Old Sep 30, 2012 | 10:49 PM
pohljm's Avatar
OH no! if you see a KKD post just completely disregard.
how do you know its slow engaging if your driving slow. flaring or slipping at all or just a lazy shift?
Old Sep 30, 2012 | 10:56 PM
don't worry. i know he's a troll. anyway. lazy shift at low throttle. only 3-4 shift, nothing else. im thinking about replacing the 4th gear solenoid. anymore than low throttle its fine. odd.
Old Oct 1, 2012 | 12:00 AM
SpiderX1016's Avatar
Try an ECU Relearn/Reset.
Old Oct 1, 2012 | 08:05 AM
nismopowerdqg's Avatar
LowNslowTL
PLEASE do a 3x3 flush and reset your ECU, your issue should be resolved. Do not replace those sensors again, those sensors unlike people think only need replacing when the "D" light starts to flash..
Old Oct 1, 2012 | 08:31 AM
SharksBreath's Avatar
BANNED
^it's a 3x3 drain and fill.
how can you tell him his issue will be resolved if he does a 3x3 and resets his ECU? you have nothing to support that theory based on what we know from OP.
do not replace the sensors again? i assure you, i would not wait until a flashing "D" appears on my dash before doing something about it. it's called preventative maintenance for a reason.
OP, when was your last drain and fill? you might want to add some redline d4 in there with the type-f. have you read inaccurates thread on redline fluid? try and follow his breakdown and get the right kinds of fluid in there.
https://acurazine.com/forums/3g-tl-2004-2008-93/optimal-percentage-racing-atf-834299/
Old Oct 1, 2012 | 08:52 AM
LowNslowTL
i own a transmission shop. i think i know what im talking about sir.
Old Oct 1, 2012 | 09:02 AM
BANNED
oh.
Old Oct 1, 2012 | 06:34 PM
https://acurazine.com/forums/showthread.php?t=834299
Thanks for the input! I already ordered another 4th gear sensor. As for the fluid, I did my last 3x3 with redline type f about 10k ago. I think I should get some D4 in there because I think it may just be the lack of a friction modifier in there at this point. Also I would like to mention that I have an external transmission cooler, just for the sake of mentioning if it makes any difference.
I will read the thread and look into a another 3x3 soon. If there is anymore (real, not KKD) input, I welcome it!
Old Oct 1, 2012 | 06:56 PM
Shark, that thread is a life saver! Thank you!
Old Oct 3, 2012 | 10:38 PM
thanks to that thread, i switched out some of the trans fluid to a 2x D4 1x Type F change and it all worked out.
Thanks KKD for being a moron... why do you bother to post.. honestly?
agupta3224
May 23, 2017 08:30 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
hashbrown
Sep 29, 2015 12:13 PM
