Slow 3 to 4 shift on AT (2005 TL)
I'm having an issue with a slow engaging 3 to 4 shift when driving slowly. I have replaced the pressure switches about 10k ago. I was thinking it might be them again. Which switch controls the 3 to 4 shift? Also, I'm using redline ATF type f
OH no! if you see a KKD post just completely disregard.
how do you know its slow engaging if your driving slow. flaring or slipping at all or just a lazy shift?
PLEASE do a 3x3 flush and reset your ECU, your issue should be resolved. Do not replace those sensors again, those sensors unlike people think only need replacing when the "D" light starts to flash..
^it's a 3x3 drain and fill.
how can you tell him his issue will be resolved if he does a 3x3 and resets his ECU? you have nothing to support that theory based on what we know from OP.
do not replace the sensors again? i assure you, i would not wait until a flashing "D" appears on my dash before doing something about it. it's called preventative maintenance for a reason.
OP, when was your last drain and fill? you might want to add some redline d4 in there with the type-f. have you read inaccurates thread on redline fluid? try and follow his breakdown and get the right kinds of fluid in there.
https://acurazine.com/forums/3g-tl-2004-2008-93/optimal-percentage-racing-atf-834299/
https://acurazine.com/forums/showthread.php?t=834299
I will read the thread and look into a another 3x3 soon. If there is anymore (real, not KKD) input, I welcome it!
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
