Several Interior Lights Out
Old Nov 29, 2011 | 07:52 PM
BustedBuick's Avatar
My 04 has several interior lights out.
1. Heated seat switch, switch works, just no light.
2. Lights on the right side of the steering wheel cruise controls
3. Some of the lights on the left side of the steering wheel
4. Shift indicator
How are these replaced?
Old Nov 29, 2011 | 08:02 PM
guitarplayer16's Avatar
Just buy the bulbs and replace them.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
The bulbs screw in and screw out kinda.
Getting to the bulbs is the hardest part.
Check out the 3G garage sticky =)
Old Nov 29, 2011 | 09:51 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
^^ Pretty much... I have about $80 bux worth of bulbs I need to buy and replace. If I'm taking my dash apart to replace bulbs.. I'm just gonna replace all of them back there.. because I'm not gonna disassemble the center console over and over again.
Old Nov 30, 2011 | 01:18 AM
ohsixMTee's Avatar
Early Shifter
That is a smart way to look at it.
When I first got mine I had quite a few interior bulbs out. I replaced them in 3 tries. lol
I'd fix a few then a few more would burn out.
Old Nov 30, 2011 | 12:39 PM
honda_nut's Avatar
2024 Genesis G70 3.3T
I've got pretty much the same lights out as the OP. How much would you think the dealer would charge to replace them? I've replaced interior lights before so I can probably do it myself over winter break, but I'm not too sure about taking out the airbag. Then again, I have taken a digital odometer out to replace the backlight on my dad's odyssey.
Old Dec 1, 2011 | 10:35 AM
ohsixMTee's Avatar
Early Shifter
It's honestly not much labor. For Acura to change all my steering wheel light bulbs it ran me like $60 bucks all together, out the door.
Old Dec 5, 2011 | 03:59 PM
imports4me's Avatar
i have this problem as well. i just bought the car under a week now and just spending this winter replacing/changing all the things to bring it back to norm....
i noticed a few of my lights are out like the OP. even a few of the lights along the side of the nav screen.....
arrghhh....seems like a whole days worth of carefully removing trims and switches....oh well......
Old Dec 9, 2011 | 06:38 PM
zex's Avatar
zex
anyone have manual to replace the steering wheel and navigation lights they are almost all out
Old Dec 10, 2011 | 01:15 AM
swoosh's Avatar
takin care of Business in
here is the DIY to replacing it:
Dont thank me....Thank DeathMetal for writing these DIY's
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-0-retrofit-oem-bayonet-housings-led-747846/ - Part 0 Retrofit of OE Bayonet Housings with an LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-i-map-light-console-746609/ - Part 1 Map Light Console
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-ii-rear-door-window-switch-w-handle-leds-746947/ - Part 2 Rear Door Window Switch w/ Handle LEDs
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-iii-steering-wheel-leds-audio-cruise-modules-763640/ - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iii-steering-wheel-746972/ - Part 3 Overview
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iv-center-vents-747870/ - Part 4 Center Vents
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-v-cluster-console-easiest-bunch-747874/ - Part 5 Cluster Console (EASIEST OF THE BUNCH!)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vi-front-passenger-door-w-rl-door-handle-led-750657/ - Part 6 Front Passenger Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vii-front-driver-door-w-rl-door-handle-led-750671/ - Part 7: Front Driver Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-viii-knee-panel-lights-vsa-mirror-etc-750880/ - Part 8: Knee Panel Lights (VSA, Mirror, etc)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-ix-heated-seat-switches-755070/ - Part 9: Heated Seat Switches
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-x-cupholder-illumination-755388/ - Part 10: Cupholder Illumination!
Old Dec 10, 2011 | 10:28 PM
overboost78's Avatar
I have several bulbs out on my back lighting on my seat heaters, VSA and steering wheel cruse control. I just replaced the ones on the steering wheel. it was a peace of cake. make sure you disconnect the car battery first it's dangerous to work with airbags and the battery connected. then on both sides of your steering wheel airbag there are 2 phillips screws one on each side. remove them and pull the airbag out then you can remove the screws for which ever switch panel you have bulbs out and replace them. I'm still trying to figure how to get my other bulbs replaced.
Old Dec 11, 2011 | 12:37 AM
swoosh's Avatar
read the post above your original post....there are DIY's posted....
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Sep 14, 2015 10:09 PM
PortlandRL
Sep 14, 2015 12:01 PM
oyayjoe
Sep 12, 2015 04:40 PM
