Seized PCV bolt
Old Jun 16, 2018 | 10:02 AM
davis.ryan23's Avatar
Seized PCV bolt
I'm trying to replace my pcv valve in my 2004 acura tl. I cannot break it free. Should I soak it in penetrating oil for a while? Somebody help plss.
Old Jun 16, 2018 | 05:22 PM
Chief F1 Fan's Avatar
moved to a forum that'll get more action good luck
Old Jun 16, 2018 | 07:15 PM
guitarplayer16's Avatar
Try PB blaster, then using a breaker bar.
I've had my share of bolts seeming to be "seized" but then switching to a breaker bar just cracks it loose like nothing.
Old Jun 17, 2018 | 12:32 AM
I just replaced mine last week and it was pretty darn easy.. It's just 2 10mm nuts, shouldn't be too tough. I just used a 10mm 6 point socket, 6 inch extension, and a 3/8" ratchet.
Old Jun 17, 2018 | 09:15 AM
stevemk07's Avatar
I have snapped a few bolt heads on my car now... Ueah soak it in penetrating oil then give it a tap with a hammer then break it free
Old Jun 17, 2018 | 03:17 PM
redbeard1's Avatar
Hi,
On my car, 2005 TL, the pcv is held by one bolt torqued to 9 foot pounds (A in the attached picture). Is it that bolt that is seized or the pcv valve itself? Several posters have had problems with the valve sticking to its housing. Sometimes the long shaft is so stuck that the shaft breaks off inside.
If your problem is the bolt that holds the PCV valve I would try PB blaster or my new favorite Kroil. Best results if you soak overnight. IMHO do not use a breaker bar for a bolt that is torqued for 9
foot pounds. That bolt should not need much muscle to remove. Too much muscle on a bolt that small will break the bolt and give you another type of problem.
If the valve itself it stuck. Be very careful as the valve is plastic and the shaft can break off inside. I would use vice-grips to hold onto the area marked B in the image and gently work it back and forth.
https://acurazine.com/forums/2g-tl-p...-cover-901203/
Old Jun 17, 2018 | 04:53 PM
nfnsquared's Avatar
LMAO at the breaker bar suggestions...
Old Jun 17, 2018 | 09:09 PM
Shit my bad.. I was talking about the EVAP purge control solenoid, not the PCV valve... Disregard my advice..
Old Jun 18, 2018 | 12:10 PM
truonghthe's Avatar
how the hell it seized? the bolt is there to hold it in place not like it was torque down to 90 FT-LBS, just for a fare share my Red TL is from CT/NYC area and yet that bolt came out easily with a 1/2 ratchet and 6 point 10mm socket.
I know it sound stupid but make sure you loosen the bolt instead of tightening it
Old Jun 18, 2018 | 12:23 PM
Maybe I should have refrained from using the term breaker bar, but generally just use something longer. If you're using a 3/8" wrench, step up to 1/2" and it should come off no problem.
It shouldn't be seized, just needs to be cracked loose.
You put in X amount of force thinking it's seized, step up to something little larger and put in the same X amount of force, comes off easy.
A small breaker bar won't cause harm, though, especially for a bolt that shouldn't be corroded
Old Jun 18, 2018 | 01:02 PM
horseshoez's Avatar
Latent car nut
The thing is, this is a 10mm bolt; I rather doubt even the most stuckest of stuck 10mm bolts can put up enough resistance to justify a 3/8 drive socket, much less a 1/2 drive monster. Heck, even my 1/4 drive socket kit has a 10mm socket, and I don't think it has ever failed to remove a bolt, regardless of how stuck it was.
Circling back to a 3/8 drive 10mm socket and wrench combo, even with that much torque I'm betting the average person could twist the head right off the bolt if it was really stuck.
Old Jun 18, 2018 | 01:06 PM
a corroded battery cable 10mm nut gave me trouble..had to break out the air impact 1/2 drive
Old Jun 18, 2018 | 01:11 PM
BreezyTL's Avatar
Just use a 6 point socket and a 3/8 ratchet. Make sure it is rotating in the correct direction and give it a few good taps with your palm. Shouldn't need more than that unless it was cross threaded when installed before, hopefully for you that's not the case. Good Luck!
Recently replaced mine and it took all of 5 minutes.
Old Jun 18, 2018 | 04:33 PM
Never mind guys I got it loose. I sprayed penetrating oil on it let it soak for a couple of days. Then sprayed it again and I got I loose. I just didnt want to snap it off.
Old Jun 19, 2018 | 10:32 PM
nfnsquared's Avatar
Or give yourself a chest hickey
jchcmax
Aug 1, 2020 08:08 AM
Black Tire
Dec 18, 2017 08:15 AM
Si_jeff
Jan 6, 2017 10:30 PM
Narbs
Nov 16, 2016 09:08 AM
