Still a lot of oil in manifold with catch can installed
Old Oct 10, 2016 | 12:38 AM
jchcmax's Avatar
Registered VTEC junkie
I have the DIY Husky oil/water separator as a catch can on the PCV side. I opened up the manifold cover to find that there's still oil accumulated in the top manifold. I thought the catch can was supposed to reduce or eliminate this? Most of the oil is on the throttle body side. Could it be coming from the intake tube? Maybe a bad PCV?
Notice the oil pooled up under the bolt
Old Jul 25, 2020 | 05:14 PM
HuskerCLS6's Avatar
I’m curious if you ever solved this? I also have a j-series V-6 in an 03 CL-S and have the same problem. I was thinking of installing a catch can but sounds like it did nothing for you, ever find out why? Not only oil, but I have excessive carbon deposits in that area as well.
Old Jul 25, 2020 | 06:39 PM
tap the other side as well, not just the pcv side
Old Jul 25, 2020 | 07:24 PM
csmeance's Avatar
and also make sure your EGR isn't spitting oil into the intake also.
Old Jul 30, 2020 | 11:33 AM
jchcmax's Avatar
I don’t think there is a solution to this area near the throttle body. The cover will have to be removed to clean this area. I think the oil is pulled from underneath the area near the throttle body. The catch can catches the oil from the crankcase on the passenger side.
By the way, the vehicle now has a Mishimoto baffled oil catch can and my brother now owns the vehicle.
Old Aug 1, 2020 | 08:08 AM
t-rd's Avatar
Unless you also bypass the EGR valve, there will still be oil. Catch can on the passenger side does reduce it but not totally eliminate it.
Aleax
Sep 11, 2015 11:31 AM
00TL-P3.2
Feb 13, 2013 10:59 AM
Dan3952
Oct 27, 2008 03:32 PM
Bobster
Aug 25, 2007 06:19 PM
Allout
Jan 26, 2006 12:40 AM
