Screeching Noise In Reverse
Old Nov 3, 2013 | 05:49 PM
AdAstra's Avatar
Mechanical Engineer
Noise comes from driver's side rear brake when in gear in reverse AND just rolling in reverse, without applying brakes.
I've done extensive searching and also tore the entire assembly apart and reassembled it today to check. I thought maybe lube issues, that one side of the pads were worn more than the other, or a material related issue but no conclusion as of now. Any other thoughts?
Old Nov 4, 2013 | 06:14 AM
paperboy42190's Avatar
wheel bearing?
Old Nov 4, 2013 | 08:40 AM
Jesstzn's Avatar
Wouldn't a wheel bearing do it in forward too? OP did you check the emergency brake assy too?
Old Nov 4, 2013 | 12:25 PM
AdAstra's Avatar
Mechanical Engineer
Actually my father and I were installing my left emergency brake assembly when we tore it apart yesterday. This noise started happening prior to that (when I had no emergency brake) and is still the same pitch and volume. Could it be that the caliper is not fully disengaging? I say that because the pads were much more worn than I expected.
Old Nov 4, 2013 | 12:42 PM
ebelp's Avatar
2014 Jeep SRT
If the pads are worn down far enough, they will start squealing even when you aren't hitting the brakes.
Old Nov 4, 2013 | 06:23 PM
AdAstra's Avatar
Mechanical Engineer
I'm thinking it has got to be the abnormally worn pads causing the noise, which may be attributed to the previously missing e-brake components. Thanks for the responses.
Old Nov 4, 2013 | 07:14 PM
acrdr's Avatar
most likely is your rear brakes .Sometimes the brake pad will shift in a way that your brake wear indicators will make noise .i would replace rear brake pads
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
