Screeching Noise In Reverse
Mechanical Engineer
Noise comes from driver's side rear brake when in gear in reverse AND just rolling in reverse, without applying brakes.
I've done extensive searching and also tore the entire assembly apart and reassembled it today to check. I thought maybe lube issues, that one side of the pads were worn more than the other, or a material related issue but no conclusion as of now. Any other thoughts?
Mechanical Engineer
Actually my father and I were installing my left emergency brake assembly when we tore it apart yesterday. This noise started happening prior to that (when I had no emergency brake) and is still the same pitch and volume. Could it be that the caliper is not fully disengaging? I say that because the pads were much more worn than I expected.
2014 Jeep SRT
If the pads are worn down far enough, they will start squealing even when you aren't hitting the brakes.
AdAstra (11-04-2013)
Mechanical Engineer
I'm thinking it has got to be the abnormally worn pads causing the noise, which may be attributed to the previously missing e-brake components. Thanks for the responses.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
