Rust under rear window
Old 07-02-2013, 03:02 PM
JustinZ's Avatar
I have an 06 TL and theres some bad rust developing under the rear window
Its pretty bad -- how should I go about getting this fixed?
and suggestions or advice??
This seems prettty bad almost like a design flow or manufacturing defect -- would goodwill cover this?
Attachment 110503
Attachment 110504
Attachment 110505
Old 07-02-2013, 03:06 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
car was repainted at some point. and poorly, at that.
i doubt acura will do much for ya.
Old 07-02-2013, 03:21 PM
MMkay.
Project_CLean's Avatar
^this.
If you mean the rear glass / windshield - I wonder if it was in a major accident that needed the quarter panel replaced? In which case, the warranty wouldn't cover it. That's bad body work.
Old 07-02-2013, 05:29 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
i havent seen this issue on any other TLs so I dont think its a widespread issue
Old 07-04-2013, 09:43 AM
JustinZ's Avatar
I've owned this car new from day 1
However, there was other rust issues, near the top right of the rear window -- and acura took it in to fix under warranty - this was a couple years ago
So now that I'm hearing you guys say it was repainted... sounds like they did a shitty job that is now causing this....
You think I have a case bringing it to them and saying their shitty job is causing the rust?
I even made a post about it here: https://acurazine.com/forums/3g-tl-problems-fixes-114/rust-above-rear-window-%2Apics%2A-635948/
Old 07-04-2013, 10:23 AM
06 Anthracite TL
erdoc48's Avatar
To fix that properly would likely require removal of the rear glass, then sanding down to bare metal, welding a new piece in place and repainting. Did it start as a paint chip in the area that received no attention? That's the only way I can think of that would result in that degree of damage. I imagine it would be a $1000 or so to fix as a very rough estimate to do it properly. You could ask Acura, but the TL is now 7 years old and it'll be hard to prove it was a manufacturing defect (well, that and the rust through warranty is likely expired).
What I find surprising in your car is that there were prior rust related repairs. In general, cars these days with intact paint don't rust. You could use that as a bargaining chip, I guess, but it'll be up to Acura corporate as to whether or not they will cover the repair.
Old 07-05-2013, 08:21 AM
MMkay.
If you've owned it NEW,and you're saying you haven't gotten into any accidents and you've already had rust issues..then you may have a case.
BTW, I'm almost positive that cars that get damaged in transit to the dealer for SALE or in the lot while moving cars,can get sent to a body shop and doesn't have to be disclosed to the customer unless it's frame damage? Correct me if I'm wrong..
Old 07-05-2013, 09:42 AM
abirvalg's Avatar
wishful thinking
pop your bumper covers off and see how it doesn't rust
or remove the interior door covers and look inside the door panels
i have had every square inch of panels not directly visible from the outside covered in cavity wax when i bought her new in 05', and i still see signs of rust in some odd places that need attention now and then
albeit none of them are on the surface
depends on the climate too i suppose
Old 08-17-2016, 08:51 PM
ackyourah's Avatar
Me Too
Resurrecting this thread from the dead...because I have rust in exact same area and I have an 06 also. I assumed it was a poorly done prior repair (I am not orig owner) but after seeing this I wonder whether anyone else is seeing it in the 3g. And wow.... a cool G to do it right.. not what I was expecting. Maybe time for a cover up? Can I get by with a cheaper repair that might last a few years? And yup I realize I could take heat for even asking that (please spare the ) but I'm trying to be practical. Thanks.
Old 08-17-2016, 08:56 PM
Received 8,623 Likes on 6,661 Posts
Just use plastidip and cover it
uzzmaan
03-12-2024 10:03 AM
BoricuaTL
04-08-2016 01:08 PM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
IIDXholic
10-08-2015 07:53 AM
max4swag
09-14-2015 07:55 AM
Quick Reply: Rust under rear window
