Rust under rear window
3 Attachment(s)
I have an 06 TL and theres some bad rust developing under the rear window
Its pretty bad -- how should I go about getting this fixed? and suggestions or advice?? This seems prettty bad almost like a design flow or manufacturing defect -- would goodwill cover this? Attachment 110503 Attachment 110504 Attachment 110505 |
car was repainted at some point. and poorly, at that.
i doubt acura will do much for ya. |
^this.
If you mean the rear glass / windshield - I wonder if it was in a major accident that needed the quarter panel replaced? In which case, the warranty wouldn't cover it. That's bad body work. |
i havent seen this issue on any other TLs so I dont think its a widespread issue
I've owned this car new from day 1
However, there was other rust issues, near the top right of the rear window -- and acura took it in to fix under warranty - this was a couple years ago So now that I'm hearing you guys say it was repainted... sounds like they did a shitty job that is now causing this.... You think I have a case bringing it to them and saying their shitty job is causing the rust? I even made a post about it here: https://acurazine.com/forums/3g-tl-problems-fixes-114/rust-above-rear-window-%2Apics%2A-635948/ |
To fix that properly would likely require removal of the rear glass, then sanding down to bare metal, welding a new piece in place and repainting. Did it start as a paint chip in the area that received no attention? That's the only way I can think of that would result in that degree of damage. I imagine it would be a $1000 or so to fix as a very rough estimate to do it properly. You could ask Acura, but the TL is now 7 years old and it'll be hard to prove it was a manufacturing defect (well, that and the rust through warranty is likely expired).
What I find surprising in your car is that there were prior rust related repairs. In general, cars these days with intact paint don't rust. You could use that as a bargaining chip, I guess, but it'll be up to Acura corporate as to whether or not they will cover the repair. |
If you've owned it NEW,and you're saying you haven't gotten into any accidents and you've already had rust issues..then you may have a case.
BTW, I'm almost positive that cars that get damaged in transit to the dealer for SALE or in the lot while moving cars,can get sent to a body shop and doesn't have to be disclosed to the customer unless it's frame damage? Correct me if I'm wrong.. |
Originally Posted by erdoc48
(Post 14562777)
pop your bumper covers off and see how it doesn't rust or remove the interior door covers and look inside the door panels i have had every square inch of panels not directly visible from the outside covered in cavity wax when i bought her new in 05', and i still see signs of rust in some odd places that need attention now and then albeit none of them are on the surface depends on the climate too i suppose |
Me Too
Resurrecting this thread from the dead...because I have rust in exact same area and I have an 06 also. I assumed it was a poorly done prior repair (I am not orig owner) but after seeing this I wonder whether anyone else is seeing it in the 3g. And wow.... a cool G to do it right:what:.. not what I was expecting. Maybe time for a cover up? Can I get by with a cheaper repair that might last a few years? And yup I realize I could take heat for even asking that (please spare the :tomato:) but I'm trying to be practical. Thanks.
Just use plastidip and cover it
