Rough idle and dying
Old Apr 7, 2025 | 10:02 PM
210nate's Avatar
Car was fine this morning got gas after work was fine till I got home I left to the gym otw there it started to act funny and not wanna move in 1st (auto car) and bogged out I got home and changed the trans fluid thinking it could be that needed changed possibly.
after changing the fluid drove it down the block was still acting werid pulled back into my drive way shut it off went to turn it back on and it started sounds cammed literally chopping, then died out and won’t start without a jump, its clicks an all electrical inside comes in but won’t start
Old Apr 8, 2025 | 07:57 AM
Jackass's Avatar
Won't start without a jump....so....first thing to look at is the battery.
- have you checked the voltage of the battery?
- have you inspected the cables, clamps, and connectors of the main electrical system?
Now if the rest of the electrical is still fully functional, but the starter never hits....that might be something different. But start with the basics first.
Old Apr 8, 2025 | 08:06 AM
210nate's Avatar
Yes I have checked the basic it started happening out of no where
Old Apr 9, 2025 | 09:04 AM
marklittlefield4's Avatar
maybe a bad tank of gas but I agree with Jackass, probably the battery
Old Apr 9, 2025 | 02:46 PM
Chad05TL's Avatar
is there a check engine light? It could be misfiring.. but that will set a code. I mean if it sounds choppy or cammed. That's pretty bad.
If a battery is so bad that it sounds cammed, then you should notice it during "cranking".
I have replaced just 1 fuel injector in 135000 miles.
muck_boy1990
Aug 7, 2014 09:45 PM
Dcisneros86
Jun 12, 2013 05:29 PM
PoundPuppy
May 22, 2013 11:42 AM
aruiz25
Apr 19, 2012 12:17 PM
shiftedTL
Dec 22, 2011 12:51 AM
