Another 5AT transmission problem... Opinion/Advice Please!
Old Dec 21, 2011 | 09:53 PM
shiftedTL's Avatar
6th Gear
my 2006 5AT 160,000mi. has developed transmission issue.
-first time in drive thru on my lunch break i noticed a louder then normal more pronounced whine from trans, within 30 seconds when pulling forward it started to slip and shudder. i made it back to work and shut off. came out after work and drove home fine, continued to drive perfect for 3 weeks
-second time in drive thru whining returned, car slipped and shuddered then would not move forward/reverse nothing! pushed out of drive thru, shut car off, went in got my food and came back out went into reverse harsh, then drove fine.
-replaced 3rd and 4th pressure switches
-3x3 fluid change
-replaced cartridge transmission filter
-car drove perfect for 300miles!
-now it has returned, i can drive the car for about 5-10 minutes shifts fine and then whine returns, transmission starts to shudder then slip then won't move
-scanned with snap on scanner at work... No codes
Has anyone had same experience... it seems to me that there is a fluid flow restriction. possibly pressure control solenoid screens? possibly transmission is just DONE!
-take it to Acura where they are almost definately going to just tell me it needs a new trans
-take it to AAMCO who rebuilt my lexus suv trans which has been perfect for 70,000 miles now.
ANY ADVICE greatly appreciated.
Old Dec 21, 2011 | 09:57 PM
shiftedTL's Avatar
6th Gear
Also the wierd thing is when car won't move i can turn ignition off for 30-60 seconds then back on and it will move fine in all gears for another 5 minutes everytime
Old Dec 21, 2011 | 11:33 PM
Scottwax's Avatar
Mr. Detail
Could be something is clogging up a passage, once you turn the car off, whatever it is drops out and down to the bottom of the pan until it gets picked up again.
Old Dec 22, 2011 | 12:51 AM
swoosh's Avatar
takin care of Business in
how many miles you got on the TL ? you could take it to Acura and have it replaced under warranty....
EDIT: you already posted that, 160K...
well try Redline Type F fluid....it might help
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
