Rough idle
Old May 19, 2013 | 03:04 PM
3.2VTEC-TLover's Avatar
Exclamation Rough idle
Hey guys, im new to the forum and just recently inherited a 2004 acura tl non S i have a couple of issues but most ive already found by searching the forum, however i have a rough idle issue. its only on a cold start for the first 1-2 minutes if not a little bit more then it dissipates and wont return even after multiple start ups. it will only do that when its cold or has been sitting most of the day at work. what could it be ?
Old May 19, 2013 | 06:30 PM
Jackass's Avatar
Rough idle is normal on cold start.
Old May 19, 2013 | 06:42 PM
paperboy42190's Avatar
normal
Old May 21, 2013 | 11:03 AM
ok appreciate it because never have i had a car do that
Old May 22, 2013 | 08:16 AM
Jackass's Avatar
When we say normal we mean that the idle will be high and it will have a slight shake/miss to it while it warms up. If I recall from earlier threads about this, it is related to the emissions and getting the cats up to temp quickly. When my wife started driving my car more, she thought something was wrong as well.
Old May 22, 2013 | 08:19 AM
buzzkill911's Avatar
It's also normal for it to turn over longer than usual before firing every once in a while. This is also an emissions thing and is perfectly normal.
Old May 22, 2013 | 08:47 AM
Project_CLean's Avatar
MMkay.
Normal as long as it's not a epic vibration or shaking. In which case, you might have read our cars have motor mount issues. Don't forget, it is/was a luxury sedan when new. So, "rough" idle is okay,within reason. But, just make sure it's not excessive.
Old May 24, 2013 | 03:26 PM
no its not, it srough for maybe a broef minute if that then it calms down its not over kill its just feels like a misfire and then smoothes out and no issues.
Thanks guys for easing my concern!
Old Jun 8, 2013 | 02:42 AM
sabermobile's Avatar
7th Gear
Just picked up an 06 6MT and experienced exactly the same thing. Glad to know it's normal and nothing to worry about
Old Jun 8, 2013 | 10:55 AM
pohljm's Avatar
you can always check your EGR as sometimes it gets stuck/clogged and will cause a rough idle. The rough idle on cold start is pretty subtle so if it is more pronounced I would check EGR.
baelim
May 10, 2018 09:53 AM
DerrickW
Nov 15, 2015 05:52 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
ceb
ILX
Sep 27, 2015 10:56 AM
