Revving issue? VIDEO INCLUDED
Old Oct 7, 2013 | 04:35 AM
paperboy42190's Avatar
So I'm not sure if this is normal or not but when I rev it in neutral/park, it revs fine but when the rpms are coming back down, right before it drops back to idle, it revs by itself like ever so slightly, then drops back down. I made a video to show what I mean. This only happens in neutral/park and not during driving.
http://www.youtube.com/watch?v=GPlW3...ature=youtu.be
Old Oct 7, 2013 | 05:57 AM
nttstt444's Avatar
I just went out to to see if my base did that and it dident. I doubt its much of a cause for concern but id be innterested to know why it does that.
Old Oct 7, 2013 | 10:18 AM
Project_CLean's Avatar
MMkay.
have you done any recent work to it? Disconnected the battery at all?
Old Oct 20, 2013 | 05:29 PM
bump
Old Oct 20, 2013 | 05:38 PM
Nick216's Avatar
The Boss
My car does this. Ive never thought much of it.
Old Oct 20, 2013 | 10:12 PM
I hate cars's Avatar
Mine does it worse when it's in the relearn process (after losing power) but it's always there a little. It catches the fall near 1k rpm and lowers to idle.
There are many reasons why especially if you've changed things like a larger TB and even a lightweight pulley. It's partially normal too, it's just the severity that can change with certain mods.
Old Oct 20, 2013 | 10:16 PM
JJH's Avatar
JJH
My car started doing this when I installed the 3.7 throttle body. When I calibrated it with the HDS tool, it went away and consistently returns to 750rpms where it's supposed to be. Used to do exactly what yours does though. Sucked with a manual.
Old Oct 20, 2013 | 10:55 PM
so this is nothing serious then? I'll just leave it alone I guess lol
Old Oct 21, 2013 | 04:41 PM
ez12a's Avatar
the overexplainer
probably an exaggerated effect of the engine or computer rather reapplying throttle to keep an idle.
i can feel sort of the same thing in a low gear and coasting to a stop, just above 1k it will lurch slightly or i get the sensation that engine braking is reduced. i'm assuming it's the throttle kicking back in.
Old Oct 21, 2013 | 05:01 PM
Especially in gear, a slight surge around 1,000rpm is the injectors coming back on and the engine coming back to life.
Those with exhaust can hear it. Under deceleration, when it's at it's loudest is when the injectors are off. That pretty quiet transition area or popping during decel is the injectors still on but the throttle at idle.
Old Oct 22, 2013 | 02:55 AM
^good info
Old Oct 22, 2013 | 08:57 PM
OnYourMarc's Avatar
i think its normal paperboy.
Old Oct 22, 2013 | 11:05 PM
thanks
sockr1
Oct 1, 2015 01:31 AM
carz0159
Sep 20, 2015 06:11 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
jliu6789
Sep 8, 2015 08:02 PM
asahrts
Sep 4, 2015 05:55 PM
