Reverse light issue
Old Feb 8, 2011 | 08:37 AM
Cali_Joker's Avatar
Reverse light issue
I just purchased my 05 TL on the 5th, I noticed my back up lights are not working when on reverse. I thought I had bad bulbs but when I opened the trunk all the way up, they turned on .... as I lowered the trunk they turned off again . I took part of the liner off to see if I can see any bad connections but didn't spot any . Anyone else had this issue before?
Old Feb 8, 2011 | 11:30 AM
LoveMyTL-S's Avatar
I had the same issue in my old Neon and it turned out to be the back-up switch in the shifter was bad. I thought it was strange that both back up lights were out at the same time.
Old Feb 8, 2011 | 12:10 PM
Cali_Joker's Avatar
hmmm... strange lol ok how can i check for that?
Old Feb 8, 2011 | 09:01 PM
Cali_Joker's Avatar
bump ... anyone ????
Old Feb 9, 2011 | 10:30 PM
Cali_Joker's Avatar
Guess im on my own on this one ... ill post the issue n fix when I find it in case this happens to someone else.
Old Feb 14, 2011 | 01:34 PM
Cali_Joker's Avatar
Ok, first real attempt to find the issue : Failed . Lol well I took apart the trunk liner n inspected the bulbs n connections, they looked ok. So then I tried to check the shifter but I couldn't get it off lol but I did notice after removing the silver trim that the previous owner had spilled what appeared to be soda all over that area which I'm thinking is the reason why the switch might be bad.
Old Feb 17, 2011 | 12:06 PM
Cali_Joker's Avatar
UPDATE !!!! According to the tech, its a small wire that's located on the left side of the trunk. It wears out over time after repeated opening and closing of the trunk. It's behind the plastic pillar that covers the support of the trunk . It wasn't making contact so he just put them back together n fixed the issue. Problem fixed, I can see when I'm backing up now since I got super dark tint lol YAY
Old Feb 17, 2011 | 12:19 PM
Bearcat94's Avatar
AZ Community Team
Good job.
Pics of where in this wire is might be nice if you get a chance.
Old Feb 17, 2011 | 12:43 PM
Cali_Joker's Avatar
I didn't get a chance to shoot some pics but ill take some when I get home of the covers to show the fix n location of the wire
Old Feb 17, 2011 | 12:52 PM
ez12a's Avatar
the overexplainer
make sense since moving the trunk causes it to go away. I dont see how it would be a shifter switch issue.
Old Aug 27, 2025 | 12:29 PM
gabytb1's Avatar
Probably you won't remember but do you know which cable is? I attached some pictures because I don't find the cable you meant.
Old Aug 27, 2025 | 01:20 PM
The OP posted this issue he had in the 3G TL forum, as well as the fix that corrected the problem within his 2011 post #7 above.
I doubt that it would pertain to the pictured hatch, above, on your 2012 RDX since it is a completely different model.
Old Aug 27, 2025 | 01:30 PM
gabytb1's Avatar
yes, I'm very sorry. I noticed it after I posted 😂😩 this sucks, but will see what fixes it!
thanks, man
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Mcj270
Aug 31, 2015 04:45 PM
