Rearview mirror gone bad??
Is there a bulb or something in the rear view mirror. There used to be a light that came on that dimmed the lights of cars behind you, but now it doesn't come on. Do I have to replace the whole thing or just the bulb? Also, is there a screw that will tighten up the mirror since it is loose and shakes while I'm driving.
If your mirror is indeed busted, you have to replace the entire mirror.
G/L.
for the mirror shaking, there's a spring inside that is warped. This happened to a few 04's and the springs were redesigned quickly and replaced. There is a really old TSB on this, I had it done in about 2006...
Just be careful with our rear views. There was a disturbing thread in hear years back where a member's broke open. He started getting a bunch of strange symptoms that were unexplainable. He later found out (allegedly) that they use mercury inside the mirrors and it sprayed all over him and his interior when it broke open. He was wrapped up in a pretty big lawsuit.
I never get blinded but see no diff when I turn that stupid switch on or off at night...
http://www.in.honda.com/Rjanisis/pubs/SB/B06-012.PDF
check the TSB section!!! and the 3G garage!!!
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
