Rattle on passenger side of dash
Old Dec 18, 2019 | 08:04 PM
01CobraVert's Avatar
Is there something common that comes loose? It comes and goes and sounds like it is behind the glove box. It changes with roads and speeds.
Old Dec 21, 2019 | 09:00 AM
GhostTL09's Avatar
Did you take the glove box out to see if there is something back there? May be time to change your filter and inspect? How long have you had the TL?
Old Dec 22, 2019 | 08:43 AM
I didn’t do anything yet. I only own the car 3 months. I figured it was worth asking before I go trying to take apart stuff.
Old Dec 22, 2019 | 11:08 AM
vpasla1's Avatar
You'll need to basically take the glove box out to change the cabin filter anyways.
Old Dec 23, 2019 | 10:10 AM
GhostTL09's Avatar
I don't recall reading on here too much about a rattle in that area although TL's can have some pretty annoying rattles and squeaks
Old Dec 23, 2019 | 12:02 PM
08KBP_VA's Avatar
I had a rattle/noise you mention in same location and took opportunity while change cabin air filter to investigate. Found bracket back there very loose and suspect was not secured when they swapped out airbag under recall when owned by PO. Tightened up and voila no more rattle.
smurfhunter
Feb 21, 2020 09:30 AM
Joe123inc
Jul 10, 2019 09:23 PM
neil0311
5G TLX Problems & Fixes
Nov 6, 2016 10:08 PM
aleo12
4G TL Problems & Fixes
Nov 30, 2015 05:05 PM
chasingthecool
Jan 29, 2011 08:49 PM
