PS Pump Inlet Bolt Stripped
Old Feb 28, 2026 | 09:49 PM
weloveacura's Avatar
I am *trying* to do the ps pump o rings. 20 min job turned into 3+ hrs and multiple days.
1st off, is this crack in the hose bad? I don't seem to see any fluid leaking yet but not sure if it cracked due to pressure or when I took it off. And where can I buy another if serious?
Inlet Hose Cracked
Inlet Hose Cracked
2nd, how the hell can I get this bolt out????? I can barely fit a wrench in there, and of course the wrench just slips right off. Where can I buy another bolt if I can even get it off? (I think this is the M6-1.0x10mm)
PS Pump Inlet Bolt.
PS Pump Inlet Bolt.
Thanks a lot.
Old Mar 1, 2026 | 06:44 PM
EasyLoveRDX's Avatar
Extractor socket. I think those are 10mm.
On K24 p/s pumps I'm using a 1/4" ratchet for those. Six-point sockets of course.
NB: definitely don't reuse that bolt
Edit: I use a set of these:
https://www.harborfreight.com/38-in-...ece-59855.html
Old Mar 1, 2026 | 10:13 PM
How in the world do you have clearance with a ratchet? Everything I've seen is only done with a wrench...
Old Mar 1, 2026 | 10:15 PM
Nevermind . I don't know how I'll be able to use those sockets with like 2" of clearance
Old Mar 1, 2026 | 10:27 PM
redbeard1's Avatar
1) that is a bad tear. even if it not leaking now, i'd get a replacement.
around 11 w/o shipping
https://www.acurapartswarehouse.com/...1-sdb-a00.html
2) i use an offset wrench to get that bolt but if the bolt is already very stripped you may need to remove pump (only 2 12mm bolts I think) and try to remove the bolt with lots of room.
https://www.tekton.com/8-mm-x-10-mm-...rench-wbe24308
new bolt if needed
https://www.acurapartswarehouse.com/...ket,1585149,18
Old Mar 2, 2026 | 07:23 AM
twokexlv6coupe's Avatar
Just unbolt the PS pump entirely, it'll give you a world of room to work with. Two 12mm bolts, one is in a sneaky location; you gotta fish the socket + extension thru the webs of the PS pulley.
Old Mar 4, 2026 | 11:42 AM
new bolt if needed
Thanks for the reply. I’ll be replacing the hose soon. Still stuck on this damn bolt. Went and bought an offset set and it doesn’t fit (hits windshield fluid reservoir). Just rounding it more.
When I get the pump off what do I use to get it from there?
Old Mar 4, 2026 | 04:25 PM
Nevermind
Old Mar 4, 2026 | 04:41 PM
redbeard1's Avatar
Nevermind
hope you got it off. for anyone else reading this in the future, the attached picture shows how to get the bolt off.
Old Mar 7, 2026 | 05:42 PM
Super glad I bought both the extractor set and offset wrenches. Both were needed. One of the 12mm mounting bolts was very close to being rounded as well.
Got the o rings replaced but the whine continues. I feel like it's even worse now. Could the crack in the hose be causing the whine??? Flush the fluid? What else do I look for now? :/
Old Mar 7, 2026 | 10:54 PM
redbeard1's Avatar
That is a large tear. It could easily let in air that is one source of the whine. When you hear the whine, remove the plug on the reservoir and check (use safety glasses) if you see bubbles. I'd replace the tube.
BTW, did you bleed the system after working on the pump? I've used the method outlined below 3 times now and never had a whine after working on my pump.
https://www.stronghonda.co.nz/how-to...ering-systems/
Old Mar 8, 2026 | 01:42 PM
Funny enough I just posted this over on the Accord forum in response to a similar-ish question:
The part of the p/s system that's under vacuum (negative pressure) is the section between the exit port on the bottom of the p/s reservoir and the pump. If you have an air leak here, the pump will suck in air. That's why Honda had that TSB for the older Accords that replaced the o-ring on the pump inlet with that new one that's red. The original o-ring wasn't making a proper seal and air was getting in.
The rest of the system does not need to be airtight.
csmeance
Jul 19, 2025 07:27 PM
back2vtec
Aug 29, 2017 08:58 AM
jedinyte120
Jun 3, 2013 08:40 AM
guitarplayer16
Nov 19, 2011 11:54 AM
Ralphie917
Jul 7, 2007 06:17 AM
