PSA - Check your PS Pump Suction Hose Bolt!
Old Jul 5, 2025 | 01:36 PM
csmeance's Avatar
I was checking the A/C on my TL today and noticed the PS Suction hose was wobbling slightly (inlet joint on assembly pic below) and the screw holding it on was loose! I rebuilt my pump in 2019 so it's been on the car for a few years without being checked. The screw was very loose (not leaking thankfully) and I used a 10mm small wrench to tighten it back up with a tiny bit of blue loctite.
Assembly:
Old Jul 19, 2025 | 07:27 PM
DrJekyll's Avatar
6th Gear
Please keep us updated if you notice it working loose again. It gets very hot in that location. Will blue loctite hold up?
I think that bolts into aluminum. Is it possible the helicoil inserts were damaged? I take it not if you were able to notice the bolt was tightening.
To add to the PSA, everyone , look at the torque spec on these! It is very easy to over torque such a small bolt.
SippinPeachSoda
Nov 15, 2024 10:45 AM
mikeyboy2011
Jul 17, 2022 06:09 PM
augwest
Jul 9, 2017 06:34 PM
kbh
1G TSX Problems & Fixes
Dec 14, 2012 09:09 AM
Ralphie917
Jul 7, 2007 06:17 AM
