Problem with switchbacks
Old Mar 18, 2010 | 03:52 PM
mike421's Avatar
Installed the 7443 switchback in the car two days ago and they worked fine. Now I installed some LED foglight bulbs in the car and the switchbacks go out but the weird thing is when you are close to the car they work but as soon as you step away they go out. If anybody knows what is going on and knows how to fix it I would appreciate it. By the way the switchbacks are from V-LEDS and they are hooked up to resistors.
Old Mar 18, 2010 | 04:07 PM
Rafiton's Avatar
LMAO are you serious, when you walk away from the car they dont work and when you are near they do. Man I swear you must be POWDER. That really funny, I hope they can help you with this problem brother.
Old Mar 19, 2010 | 07:30 PM
jptl04's Avatar
Bone stock tl-s
i friend of mine had the same problem. but his worked when they were in shade and as soon as the sunlight hit them they went out. resistors installed and all. they were also from V-leds. return them and get new ones they are obviously a defect.
Old Mar 21, 2010 | 07:12 PM
SlimTL's Avatar
mike421, the new V-leds switchbacks are not a defect. They have a sensor built in that dim the white of the bulb if it senses enough external light source.
Apparently, the new 3-chip switchbacks are the ones that dim the bulb.
You can use this thread for reference where I helped out another poster with the same issue.
https://acurazine.com/forums/3g-tl-problems-fixes-114/crazy-switchback-problem-help-764560/
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
