Problem with HID Fog Install Need Help
Old Aug 27, 2007 | 12:26 AM
07_TLS's Avatar
Hey guys I'm new to the forum. I Purchased a 07 tls a few months back . Just now got a chance to convert my fogs to hids in 3000k. I am having a bit of a problem with the install. I am running an express harness w/o relay . When everything is plugged in once the fog switch is activated one side of the fog flickers for a few seconds then shuts off.
What I want to know for the ones tha have converted your 07 tls to hids are you having the same problem. I tested the hids directly to the battery all works fine so it cant be a defective part. I am guessing it requires a full relay harness to run .
I figure I come on this board to confirm before i order a relay harness for my fogs
Old Aug 27, 2007 | 12:35 AM
lookinco's Avatar
B A N N E D
You need to run a relay and get battery directly from the battery.
Old Aug 27, 2007 | 12:42 AM
07_TLS's Avatar
I was just waiting for someone like you to confirm. Thx alot.
BTW did I see right.
3.5TL S/C?
Old Aug 27, 2007 | 01:45 AM
DNPhotography's Avatar
Photographer
im not running a relay. i have a set of 3000K in my fogs are they are just fine.
Old Aug 27, 2007 | 12:03 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
Like stated previously... it's best to run these HID kits directly from the battery with the use of a relay... however, you can change the underhood foglight fuse from 10 amps to 15~20 amps... If you check... it's probably blown right now...
Good Luck
Old Aug 27, 2007 | 12:59 PM
07_TLS's Avatar
Good Luck
after my failed attempt when u put the halogen's back yes it did blow the fuse. So your saying if i want to avoid runnind a full relay harness all i have to do is up the fuse to avoid flickering?
Old Aug 27, 2007 | 01:22 PM
rodneyc77's Avatar
I would UP the fuse as a temporary measure... 'cause Honda used thin wires to power those bulbs and they wouldn't handle the extra load for a long period of time...
Please do the right thing and use a RELAY to power the HID's directly from the battery...
Old Aug 27, 2007 | 01:32 PM
07_TLS's Avatar
Oh don't get me wrong I don't plan on half a**ing a 37000 investment. I wanted to get it working temporary until I get the relay harness in from the place I got my hid fogs from. In any case thx for all of your help.
Old Aug 27, 2007 | 01:42 PM
rodneyc77's Avatar
no doubt.... let us know how it goes...
cycdaniel
Dec 17, 2019 10:58 AM
InFaMouSLink
Oct 27, 2015 06:51 PM
pozebly
Sep 23, 2015 07:30 AM
NSolace
Sep 3, 2015 08:02 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
