Is this a problem?
Old Jul 6, 2009 | 03:51 AM
RJNN TL's Avatar
Ryan's loving his ATLP TL
Is this a problem?
I've been hearing while engaging into Drive lately. I loud SLAP from the engine . It doesn't happen all the time, mostly in one spot. I drive backward down my friends driveway and then come to a SLOW rolling stop(2 MPH max) then I shift into Drive and I hear this SLAP! Is it possible my transmission is going? OR is this another regular thing about the TL's noises. Just curious.
I own an 05 TL Auto. 83K on body of car. 62K on Engine only.
Old Jul 6, 2009 | 04:03 AM
RJNN TL's Avatar
Another thing is. My headlights are already going a little fuzzy. They are beginning to fade, the plastic around it. Hmm..
Old Jul 7, 2009 | 02:32 AM
RJNN TL's Avatar
So no buddy knows? Or.
Old Jul 7, 2009 | 12:28 PM
TL|GTX's Avatar
A Black TL
Yes you need to wetsand your headlights, and that noise is not a problem, but try stopping all the way, and shift and see if you can still hear the sound. But my 08 TL has the same sound anyway.
Old Jul 11, 2009 | 05:40 PM
RJNN TL's Avatar
Can you tell me a little more about the Wetsand? And thanks for telling me not to worry about that problem. It's just always been like that.
Old Jul 11, 2009 | 09:41 PM
csmeance's Avatar
Come to a complete stop when shifting into drive. As well check the condition of the trans fluid, new fluid is always good.
There are two ways to go about fixing the lights:
1. If it is severe, wetsanding will be needed. Start with 800 grit sandpaper and sand back and forth, never in circles. Then go with 1000 grit and go up and down. Then with 1500 and go back and forth. Then 2000 and go up and down. Then go with 3000 and go back and forth. Polish out lights with some Light Cut compound.
2. Minimal hazing - Use some Optimum Compound on an orange pad at speed 5-6 and polish out the lights. then follow up with Optimum Polish at speed 5-6 and finish it off.
The hazing will come back sooner or later, 2 months or 2 weeks. Your best bet is to fix them completely and have some clear-bra put on top of them.
Old Jul 12, 2009 | 09:25 PM
shftl's Avatar
Old Jul 12, 2009 | 09:51 PM
Oracle_Oracle's Avatar
I get the same noise under these conditions with my '08. Any idea what is causing it?
Old Jul 14, 2009 | 10:13 AM
Majofo's Avatar
the 'SLAP' sounds like it could be a mount.. what happened to your original engine?
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
