Power Window Going Too Far Up
Looking for advice with the driver's side power window on a 2005 TL. The problem is the window is going up to the point it actually deforms the door. I can see the outside mirror move! Once I release the button it releases the pressure and the door returns to it's normal shape. It does this if I just hold the button on or if I use the auto up feature. What should be telling the motor to stop? Obviously I can release the button but that isn't really a solution and that doesn't help so much with the auto-up.
Jokerman
I think you are talking about when it creates the seal. When the window goes all the way up, it does push out the door a little, this is due to the curve in the window and to help create the seal. thats my opinion on it, mine does kind of the same thing
xsilverhawkx
09-28-2015 06:51 PM
