Possible Tranny Issue
Old Mar 10, 2016 | 03:46 PM
AJandTone's Avatar
Question Possible Tranny Issue
I've searched everywhere but can't find any similar posts to the problem I'm having.
I Finally buy a car, that if maintained properly, should live to see 200k.
But through all my searching all I read is 2008 AT transmissions are bound for failure after 100k..... well here I am, just passed my extended warranty at 103k...
Anyways... heres the issue.
After braking and coming to a complete stop, my cars feels like its on the verge of stalling, while the power loss occurs I am feeling a slight vibration or shudder in the steering wheel while idling. I never feel the transmission slip or anything but I'm starting to think its a torque convertor hanging up or forgetting to engage...
I dont think its:
  • spark plugs
  • braking system
  • fuel system
  • bad gas
But welcome any suggestions..
PLEASE HAAAALLLLP
Old Mar 10, 2016 | 04:53 PM
Scottwax's Avatar
Mr. Detail
Vacuum leak, problem in the EGR system and spark issues (coils or plugs) can all cause low speed shuddering, idle issues and vibration.
Old Mar 10, 2016 | 07:26 PM
AJandTone's Avatar
Thanks for you input.
I just sprayed starting fluid all around the intake and didn't hear any change in the idle.
Although keep in mind, my car doesn't idle rough in park, only in drive and after I brake.
Old Mar 13, 2016 | 08:38 AM
Scottwax's Avatar
Mr. Detail
My first Honda Accord would do that, turned out to be carbon clogged EGR passages in the manifold.
Old Mar 13, 2016 | 09:03 PM
AJandTone's Avatar
I think it's the break booster. A vacum leak or something
Old Mar 16, 2016 | 02:21 AM
csmeance's Avatar
I dont think its:
  • spark plugs
  • braking system
  • fuel system
  • bad gas
PLEASE HAAAALLLLP
do the RPMS drop a lot and vary a bit with the A/C cycling on and off? If yes, your car battery might be dying and the ECU needs to relearn the idle. Very easy to perform. You'll notice things like memory seats won't work all the time
Old Mar 16, 2016 | 08:28 AM
AJandTone's Avatar
I have a few things hardwired to my rearview mirror, and sometimes I notice my dash came will take a few minutes to turn on.
The reason why I know this Is because typically it turns on instantly and says a Start Message.
I just had the battery replace after the notorious HFL drain.
And I havent noticed and problems with my memory seats.
Have either of you had any problems with the brake booster line?
Old Apr 29, 2016 | 07:16 AM
AJandTone's Avatar
Figured out what it is...
EGR Valve was clogging, eventually got stuck open and the idle became unbearable and threw a code.
FINALLY!
coug66
Feb 12, 2016 06:38 PM
teggymike410
Feb 3, 2016 06:44 PM
mpcook
Jan 30, 2016 09:19 PM
DJMikeT
Jan 16, 2016 02:18 PM
