Possible clock solution... Will test and report back
Going through the 07-08 FSM, I found a section within the wiring schematics for the nav display panel. There is a red/yellow wire that supplies GPS clock sync signal to the nav unit. In the case of an open (cut) wire, FSM states the clock will default to 1:00 when Gps signal isn't found. Whole that's not really helpful, a subsequent reset of the nav unit may reenable the manual clock adjustment. There is also a nav display reset procedure that will reset the clock to 1:00 without pulling fuses or disconnecting battery.
will report back soon.
TW Type S (01-07-2022)
Wasn't the purpose or mentioning it. Lol. I know it resets at 1. I'm working on a long term viable solution and have contacted the company that writes the software. Just going to experiment with different things in the meantime.
Hyperblu (01-05-2022)
Y2K22 Acura Clock Bug: https://tiremeetsroad.com/2022/01/03...ncorrect-time/
Reset my recently incorrect 2008 clock to 1:00 at 1:00 local time today using this method. I know the item in question here is if snipping the red/yel wire and reset will unlock the manual controls, but just wanted to say thanks for posting the easy method of resetting the clock to 1:00. It is a good enough work around for me for now until something else comes along. Thanks!
ex_hacker202
01-22-2018 01:41 PM
ScottRL
02-05-2015 05:52 PM
2002TLSNavi
08-04-2007 01:45 PM
