How to Hard Reset the Nav Unit
Old Mar 5, 2011 | 06:37 PM
ScottRL's Avatar
My Nav unit in my 05 RL started acting up again. Ejecting the Nav disc or pulling the fuse would do a soft reset that would briefly help. When I had the car in at the dealership, they did a hard reset - which wiped everything clean - home - address book - previous destinations....everything (except radio presets)
The hard reset worked great - the Nav unit again functions flawlessly. (It would previously get disc read error, hang, take forever,....
Is there a way to hard reset the Nav unit without taking it into the dealer??
Old Mar 25, 2011 | 09:44 PM
av2600's Avatar
i think the only way is to disconnect the negative battery terminal. make sure you have the security codes handy
Old Mar 25, 2011 | 10:09 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
No that will not wipe the Nav clean. You have to go into the service menu by pressing MENU+MAP+CANCEL
Once the service menu is up the reset option is under one of the menu selections. I just don't recall off the top of my head.
I know because I did this once. Wiped everything, messages, address books, previous destination and preferences.
Old Mar 28, 2011 | 10:42 AM
nynruas's Avatar
I'll have to try this. I've had my RL for about 2 years and have not been able to use the navi for anything but as a map because anytime I try to actually use the navi to set a destination or anything, it'll lock up on me. Dealer tells me I just need to update DVD disc, it seems more like a software issue than a DVD issue.
Old Jul 28, 2011 | 05:38 PM
RLfromHell's Avatar
9th Gear
I just updated my 2005 RL's nav. to the most current version from 4.13 but and still having issues. The nav. tries to self diagnose itself every time I start it up. I can bypass this by pressing Map/Guide Menu Cancel.
The dealer said they need to send out the unit and this will take up to 3 weeks and $500-$600...
It doesn't seem like it should be a hardware issue to me.
Think a hard reset will help?
Old Feb 5, 2015 | 05:50 PM
Maurico's Avatar
Reset 2100 TSA nav system
I pressed -menu,map and cancel- all 3 at the same time. It took me to a screen that allowed me to run diagnostics on all the systems. I was then able to connect my phone.
Old Feb 5, 2015 | 05:52 PM
Maurico's Avatar
Note: You must tell it to run the diagnostics.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
