Popcorn sound??????
Old Apr 14, 2010 | 10:16 PM
05TLRIDER's Avatar
Popcorn sound??????
My TL developed a nice little sound earlier this week. I have no idea how else to describe it, but it sounds like popcorn popping and is coming from the front passenger side wheel area. I don't hear the noise at high speeds, only at low speeds - but it's honestly when I'm slowing down (not quickly either, but at a normal rate) the noise appears between 2-0 mph, and then I hear it between after letting go of the brake pedal and barely touching the gas pedal. Sometimes it's been 10ish pops and other times it's only one or two.
Anybody have any guesses? It's on an 05 auto TL.
Old Apr 14, 2010 | 10:46 PM
road_boy's Avatar
Maybe the CV joint needs to be changed, check the boot to see if its ripped or check to see if grease has leaked out from the boot.
Old Apr 14, 2010 | 11:09 PM
05wdptl's Avatar
my car does a popping sound almost every time i do either slow full left or right turns... happens alot when im like backing out of a parking spot and what not... its kinda annoying too =[
Old Apr 15, 2010 | 11:55 AM
05TLRIDER's Avatar
That's what is odd....I don't hear it when I'm turning. Only when I'm decelerating or accelerating. I'm not sure whether to take it to the stealership or not. I'm a little nervous that it might be axle related, but I don't notice anything in the steering wheel or in the brake pedal.
I hate diagnosing "noises" in a car!!
Old Apr 15, 2010 | 12:28 PM
shadowkahn's Avatar
Why not turn the steering wheel all the way to the left and look under there to see if you see anything amiss?
Oh, and 05wdptl, you may have bad CV joints. Check to see if your boots are torn.
Old Apr 15, 2010 | 03:40 PM
AJ@ECSMotorsports's Avatar
Former Sponsor
Sounds like a CV issue, unfortunately.. when it comes to noises and suspension, I agree... its a PITA just to find out exactly what it is, if not obvious.
Old Apr 15, 2010 | 07:54 PM
wasupdog's Avatar
My Garage not
i had a creaking/popping sound coming from my right passenger side when turning at really low speeds. i only heard it when i was coming home and parking. it was my serpentine belt tensioner pulley.
if u stand outside of the car with it in D and the parking brake on, pop the hood and turn the wheel from outside of the car and see if it's coming from that area.
Old Apr 15, 2010 | 10:16 PM
05TLRIDER's Avatar
Well I got home late tonight and have to be at work early tomorrow so it looks like this will have to wait until the weekend comes around to investigate. Thanks for giving me a few ideas guys. I'll let you know what I find.
Old Apr 16, 2010 | 07:46 AM
ross7778's Avatar
I have this same noise. It doesn't happen all the time though. Seems to depending on the weather. In the winter I hear a clicking sound when I turn left. I bet they are related. Could it have something to do with the brake calipers?
How many miles on your 05? I have 46,000.
Old Apr 16, 2010 | 02:40 PM
05TLRIDER's Avatar
^^ Funny you mention that it's intermittent, because I haven't heard it at all the today! And I was out driving between construction sites for work today. Someone I work with thought it might be related to the calipers, but I would think that I'd feel something in the brake pedal. I'm almost at 83k right now.
Old Apr 21, 2010 | 10:29 PM
05TLRIDER's Avatar
Tonight I put the car in neutral, lifted it and turned the wheel by hand and from what I can tell the noise came from where the axle connects to the transmission...I think. The car wasn't high enough for me to get under it to find out for sure. Any thoughts?
Old Apr 22, 2010 | 07:45 AM
ross7778's Avatar
CV Joint? My noise came back yesterday. Not when I turn the wheel though. Seems like it happens when it's warm out (70+) and my car has been sitting for a few hours.
Old Apr 25, 2010 | 10:20 PM
ross7778's Avatar
I lifted the car today and I've determined it could be a couple things. One is the stabilizer link. I noticed one of the rubber boots was torn so some dirt/sand could have gotten into it.
The other source could be the brakes. I took them apart and noticed there were no shims. According to the shop manual there should be two for each brake pad. I pressed the pedal and noticed a popping sound. I cleaned the pads and calipers and re-greased them but it didn't seem to help.
Old Apr 25, 2010 | 10:45 PM
05TLRIDER's Avatar
Interesting. I actually took my car to the dealership Friday and they were not able to figure out what it was coming from. They checked all boots and joints, and also checked torque on all the bolts associated with the front suspension. I talked to the service manager and we took the car for a drive and before hardly leaving the parking space I heard the noise. He had no idea what it was coming from and said to maybe hold off on checking anything else until it becomes more pronounced. I agreed to that since he didn't charge me anything, which was awesome! I was thinking about the front stabilizer bar and wondered if it might be an endlink or something. My only other guess is that I'm thinking it's a strut. I noticed that it didn't make the noise yesterday when it was raining out.......but not sure what that means.
Old Apr 26, 2010 | 07:34 AM
ross7778's Avatar
What dealer did you take it to? I took mine to Bloomington Acura last year and they kept it overnight. Didn't end up finding anything but at least they didn't charge me and I got to try a 2009 TL.
At any rate I'm going to order a set of shims and see it that does it.
Old Apr 26, 2010 | 07:51 AM
1995hoo's Avatar
Keep Right Except to Pass
This one in particular sounds symptomatic of bad CV joints. I had the same problem when I had a 1986 Legend and both joints had to be replaced. Unfortunately it's not a cheap repair, but it's vital that it be done if that is indeed your problem. Don't put off having it checked.
Old Apr 26, 2010 | 08:56 AM
05TLRIDER's Avatar
I took mine to Buerkle - that's where I always take my car. I didn't realize you are in MN. You should lookup our Twin Cities thread on here and try and make it to the next meet.
Anywho, let me know if the sound goes away after you install the shims. I'd be willing to meet up with you to see if we're experiencing the same sound as well.
Old Apr 28, 2010 | 03:48 PM
lowbudgetTL's Avatar
I have 98,000 on my 2005 auto... The clicking noise started around 35,000.. Winter 2007 or so. only does it when its cold out.... once car/engine/ect is warm It dissapears. but the other day I heard it when it was 45ish outside
so I'll be taking it to my mechanic soon for Cat-deletes and HFC plus the 105,000 service. Hopefully we can find it
Old Apr 28, 2010 | 05:31 PM
1fsthatch's Avatar
Im having the SAME EXACT issue as you only when its cold out, when i make a turn please let me know what you find out so i can point the dealer in the right direction
1000th post
Old Apr 28, 2010 | 07:11 PM
pastaVTEC's Avatar
1000th post
Where's my intake? You have my money, but I have no intake!
Old Apr 29, 2010 | 07:20 AM
ross7778's Avatar
Same issue with my 2005 auto. When it was really cold this winter it would start clicking on left turns. No clicking noise so far this spring. I have 47,000 miles on mine.
Old Apr 29, 2010 | 10:30 AM
05TLRIDER's Avatar
^^ Are you lowered ross? I'm wondering if this is the beginnings of a bad strut perhaps. I installed Eibach springs last year on stock struts, and am thinking that may be part of it..... I'm thinking about looking at the sway bar endlinks this weekend if I have a chance. Did you get the shims yet?
Old Apr 29, 2010 | 11:05 AM
Yeah it starts on the left then both sides
Old Apr 29, 2010 | 06:34 PM
ross7778's Avatar
I am not lowered. 100% stock. I do however use rims from a 2003 Type-S for my snow tires in the winter.
The popcorn sound has been silent for the last couple days. I did not order the shims but I did put some multi-purpose grease into the torn stabilizer link boot. I have no idea if that did it or if it was overhauling the brakes.
Old Apr 29, 2010 | 08:36 PM
05TLRIDER's Avatar
Funny, cause I haven't heard the noise for the past couple day either, but I heard it this afternoon on the way home from work! Did you by chance take a pic of the torn boot? Is it torn where it connects to stabilizer bar? I absolutely hate weird/random noises on my car and have actually been working on de-rattling my car tonight. I'm gonna be doing some pretty serious work this weekend hopefully. Maybe I'll find the cause of this noise!
Old Apr 30, 2010 | 07:27 AM
ross7778's Avatar
The torn boot is the upper one where it connects to the wheel.
Old May 16, 2010 | 09:49 PM
clintrob's Avatar
clintrob
I have the exact same issue. Has anyone isolated the cause yet? I would like to point the dealer in the right direction to get this fixed. Thanks!
Old May 26, 2010 | 07:04 AM
ross7778's Avatar
I installed the shims on the front brakes and the squealing went away but the popcorn sound is still there. I wasn't able to replace the stabilizer link. I didn't have the right tools and it's a little awkward to get to. The boot is torn though and I'm fairly certain it's making the noise. My left stabilizer link also seemed a little loose so maybe all the bolts just need to be tightened.
Old May 26, 2010 | 11:05 PM
05TLRIDER's Avatar
I'd be interested to know how the hell the bolts come loose if that's the case, because I had to cut the bolts off my rear sway bar endlinks when I replaced that last summer! Keep me posted though. Thanks!
Old Nov 12, 2013 | 07:35 PM
mattymattB's Avatar
From Around The Way
Sucks how all these details go into some of these threads to just leave them unanswered....
Instead of starting a new thread does any one know if the solution to this would be the stabilizer links ? Im experiencing that popcorn sound at like 0-2mph
Old Jun 13, 2017 | 06:15 PM
Acuratl2005owner's Avatar
Any ideas about this strange popcorn sound at idle / low speeds. Strangely mine is at night time.
Old Jun 14, 2017 | 10:12 PM
Superunknown's Avatar
If the air mix controllers under the dash have gone fucky, it'll sound like muffled popcorn.
Old Jun 15, 2017 | 09:01 AM
Kevin17112's Avatar
I have 08 TL and mine also makes clicking sound on left turn but only during cold or warm weather. I doubt it's the axle. Has anybody found a solution to this problem?
Old Jun 15, 2017 | 09:02 AM
lol it's the axle fool.
clicking on left turn is tell tale sign
Old Jun 15, 2017 | 10:01 AM
nfnsquared's Avatar
Left turn clicking=passenger side axle joint. Right turn clicking=driver's side CV joint.
Check the boot. You can pull the axle and rebuild the joint yourself if you're so inclined. If the boot is torn, you may just need to clean out the joint, regrease it and install a new boot.
Time wise, it's quicker to just replace the whole passenger side axle. If you take that route, then you'll face a decision of whether to use aftermarket axles, OEM axles,or Raxles. The aftermarket axles don't have the harmonic donut on them, but they seem to work fine and they are dirt cheap compared to OEM or Raxles. Raxles repurposes used OEM axles with better joints/grease.
Old Jun 15, 2017 | 11:50 AM
coykiam's Avatar
About 6 months ago I had a clicking on my 06 when I turned right...turned out to be the driver side axle. Then a couple months ago the clicking started when I turned right so I brought it into the dealer since it was still covered under the warranty.
SA called me and said I had a leaking power steering rack......A couple days later dealer called and said the car is ready. I walked in with a lube and bent over and the clicking sound disappeared when I drove my car.
Could a power steering rack cause the clicking?
Old Jun 17, 2017 | 08:26 PM
6MTrules's Avatar
LeftFoot, RightHand Happy
Popcorn from passenger side engine compartment = side motor mount. At least for me.
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
saturno_v
Sep 27, 2015 08:13 AM
