PO174 System too Lean Bank 2
This is for an '04 TL.
Where is the O2 sensor located for this?
Also, what is the Part # for this?
Is there a DIY on this site to replace it? I could not find one.
Where are 2 O2sensor there are upper and lower on the exhaust system. But you need the scan tool to find which one is bad.
http://www.acuraoemparts.com/delray/jsp/home.jsp
-------Tim-------
This link has some info...
https://acurazine.com/forums/3g-tl-problems-fixes-114/p0174-code-need-new-o2-sensor-how-install-836473/
Another....
https://acurazine.com/forums/3g-tl-problems-fixes-114/im-getting-p0171-p0174-code-846356/
Another....
-------Tim-------
Here is a link to a diagram. The front cat converter has 2 sensors. You will need either 10 or 11, and I am not sure which you need. You can order through a vendor here on Azine ( could be cheaper?).
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I don't quite know for sure. But my CEL lights keep on turning off and on with this code. On for 1 day; Off for months.
I have new fuel injectors, I did a valve adjustment. New air filter. Aside from a leak test which I do not know how to do, I am looking at the 02 sensor. I had a PO171 code before. It went away permanently after the valve adjustment. So I'm taking a stab at the O2 sensor. Not sure what else to look at.
08_UA7_Gr33k
02-11-2016 02:17 PM
SiClone
10-01-2015 10:22 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
