I'm getting a P0171 and P0174 code.
Old Feb 2, 2012 | 04:39 PM
Nycknicks105's Avatar
Sorry, but I know we have some threads about this same issue, but a lot of those threads are either old or dead.
I don't know too much about cars, but after reading the older threads I can tell that both my banks are running lean. And not enough air is going through my system.
I took it to my friend and the CEL went away, but the messages was stil there. I drive for another 45 min and the CEL came back again. Also, my gas mileage is TERRIBLE. I just filled up on tuesday and I'm 1/4 away from empty. I've driven close to 300 miles so far.
I went to Acura and they told me that this isn't covered by my normal warranty. And my valves probably have to be readjusted. They didn't run a diagnostic or anything, but the guys seemed to have a lot of knowledge about this issue. He gave me a quote of $420 to fix this problem for me.
Can someone tell me what's going on with my car and if that price is fair?
Thanks!
Old Feb 3, 2012 | 08:06 AM
Damian0216's Avatar
If I'm not mistaken those are lean codes. O2 sensors most likely. I had it done under warranty took them forever to listen to me and replace my o2 sensors. They ended up replacing my injectors, ecu, reprogramming my ecu and finally o2 sensors. If they tell you its not under warranty go to a different dealer.
Old Feb 3, 2012 | 08:26 AM
EL_PIC's Avatar
Rich and Famous
Originally Posted by Nycknicks105
... I went to Acura and they told me that this isn't covered by my normal warranty. And my valves probably have to be readjusted. They didn't run a diagnostic or anything, but the guys seemed to have a lot of knowledge about this issue. He gave me a quote of $420 to fix this problem for me.
Thanks!
Hogwash.
Your Warranty covers this unless you abused the car
and fouled up the intake someway.
There are an increasing degree of O2 sensors failing these days and there is something wrong with this situation ...
I blame the ethanol.
But if you operate your car normally you need to go to another dealer for Warranty work.
Hogwash is only to clean hogs.
Old Feb 3, 2012 | 09:38 AM
They did say It doesn't cover my warranty, because I went past the 4 yr/50k warranty. I have an 2008 Acura TL with 53k miles on it.
Old Feb 3, 2012 | 07:13 PM
Damian0216's Avatar
argue with them that you ronly 3k miles over the warranty .... its the kind of things they will say to you since they want to make some money off you....
Old Feb 15, 2012 | 06:18 PM
primus's Avatar
valve adjustment
Old Feb 15, 2012 | 07:40 PM
pohljm's Avatar
my 2006 is 7 and 70,000? 2008 is less? or perhaps not drivetrain?
Old Apr 10, 2013 | 07:31 PM
Lazer187's Avatar
The 02 sensors your referring are those the ones off the primary cats??? (Are those the only 02 sensors?)I too am getting both of these same error codes. I'm scheduled for the updated pgm-fi software as stated by acuras tsb 08-043. If that doesn't work I think I'm going to replace the 02 sensors. Can some provide me with the 02 sensors that would be replaced to correct this problem? Thanks in advance. FYI my car is at 64k miles if that matters
Old Apr 11, 2013 | 04:44 AM
Timstandupguy's Avatar
Yea i just did the last measure a valve adjustment last month everything seems to be in sync and now after changing out a Map sensor , purge valve sensor and the Pgm Update. i notice the gas mileage increase and the car felt much better so those are the steps you have to take. 68K on mine and i think i the dealer solve it
Old Apr 11, 2013 | 04:46 AM
Replace the top o2 sensor in the front aka the map sensor or LAF sensor
Old Apr 11, 2013 | 09:26 AM
Lazer187's Avatar
Do you know the acura OEM part # IS it this one? 37830-PNC-003 SENSOR ASSY., MAP 2007 TL 78.63 58.97 Qty:
Old Apr 11, 2013 | 12:44 PM
lowd77's Avatar
'07 WDP TL-S
I had these same codes after cold starts...took to dealer and after they diagnosed it for an hour and a half they recommended a valve adjustment. I had them do the adjustment and haven't seen the codes since. I had 62000 miles on the car. The engine is noticeably quieter....no ticking noises...and has a smooth idle again.
Old Apr 11, 2013 | 02:51 PM
ep3kid914's Avatar
my car at 174k had both codes come at the same time and it was because of the gas and weather (btw i live in ny and it happened during the snow storm) try changing gas and reset the computer with the obd2 reader or disconnect the battery
Old Apr 11, 2013 | 03:32 PM
Lazer187's Avatar
Yeah i tried that one two times, with running Fuel Injector Cleaner both times for two tanks fills. No luck the CEL came back on after 50 miles... FYI does pulling the battery cable actually Erase/reset the error code? I mean it goes away for a little while, but I remember on my wifes 03 VW Diesel Jetta, we needed to actually take it to the dealer ship to have them reset the code.
Old Apr 11, 2013 | 05:12 PM
ep3kid914's Avatar
maybe its your 02 sensor then well i did that when they came out like 2 months ago and they never came back plus i connect the obd2 reader just to make sure since i needed to pass inspection in ny and no codes appear
Old Apr 11, 2013 | 06:24 PM
Lazer187's Avatar
What is the OEM part # for this 02 sensor? and are those the ones off the primary cat? did you replace both?
Old Apr 13, 2013 | 02:50 PM
Lazer187's Avatar
I too am getting both of these same error codes. I'm scheduled for the updated pgm-fi software as stated by acuras tsb 08-043. FYI my car is at 64k miles if that matters
Just an update, so i took my car in yesterday for this PGM-FI software update and i currently drove 80+ miles and it has yet to come back on!.... Hopefully this will be the last of the CEL coming on.
Tim Giron
Mar 18, 2016 09:50 PM
rklatzkin
Sep 23, 2015 04:08 PM
edexcsc
2G CL Problems & Fixes
Sep 21, 2015 01:00 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
