P0174 code, need new O2 sensor? How to install?
Old Oct 20, 2011 | 04:13 PM
gogators22's Avatar
Question P0174 code, need new O2 sensor? How to install?
ok guys, today, 10 days before I have to renew my tag (and get my FIRST emission inspection since buying my car in March, I got my SECOND CEL.
First time, as an APP sensor.
Today, it was business as usual, until I looked down and saw my CEL light.
This was my reaction:
So far, I've read that it could be anything from shitty gas to a valve adjustment.. Does my 2004 auto TL have a MAF sensor, and if so, should I try to clean it first?
If it's a "lazy O2 sensor", how do you replace it?
Old Oct 20, 2011 | 07:21 PM
vill0169's Avatar
AZ Track Whore
No MAF's for us. Google says its the #2 bank (so the rear one) and it's probably the primary or top one. Once you get to it, it's not too hard to replace with an adjustable wrench.
Old Oct 20, 2011 | 10:10 PM
gogators22's Avatar
what isn't hard to replace? the bank? what is a bank? where is it located on my car? sorry, Im a noob
Old Oct 21, 2011 | 01:50 AM
nfnsquared's Avatar
negative, bank 2 is the front. Bank 1 is on the head with cylinder 1 (rear).
Old Oct 22, 2011 | 09:00 AM
gogators22's Avatar
my friend is a mechanic and he says this is a problem with my cat... is this real life?
Old Oct 22, 2011 | 12:13 PM
nfnsquared's Avatar
99% sure it's not the cat...
Are you sure there were no other codes in addition to P0174?
First thing I'd to is reset the code and see if you get another MIL. If you get another MIL, get the codes read again (Autozone will do it for free and give you print outs).
Here's the Service Manual info:
Old Oct 23, 2011 | 04:51 PM
gogators22's Avatar
Thank you kind sir.
The CEL went away on it's own. Car is driving fine. I filled up with better quality gas, thought that might have been a factor. I shall do an ECU reset next.
Old Dec 26, 2011 | 07:19 PM
Paul91's Avatar
Slight bump here....have this code with my newly purchased CPO'd 07' TL-S. I believe this is covered, but in the CPO warranty it mentions that O2 sensors are NOT covered. Is it possible for the O2 sensor(s) to become fouled due to these bank/fuel system issues? Just trying to cover my basis before I do battle with the dealership.
Old Dec 27, 2011 | 04:44 PM
lilusadude's Avatar
Yes, I do believe O2 sensors can fail due to unfavorable fuel conditions occuring in the respective bank. If the dealership finds other faulty sensors that deal with A/F ratio then it shouldn't be hard to argue your case.
Old Jan 26, 2012 | 06:40 PM
gogators22's Avatar
code back on, same problem. is there a DIY to replace my 02 sensor, and how much should I spend for the part?
Old Jan 28, 2012 | 05:20 PM
gogators22's Avatar
herp derp O2 sensor herp derp
Old Dec 13, 2013 | 05:27 AM
robocam's Avatar
So what ended up happening to your P0174 code?
Hi, did you ever figure out what was causing the P0174 code? My 06 just threw that code today. I cleared it hoping it wouldn't come back. Maybe it's fuel related. I just refueled a day ago. The temperature also dropped down to 7 degrees F this morning.
Old Jan 11, 2014 | 09:22 AM
Josh73's Avatar
hey guys my 06 just threw codes for p2138 which i just changed in like october, p0174, abs 61-1,83-1,86-1.not to sure what to do any help?
Old Jan 12, 2014 | 02:17 PM
Josh73's Avatar
nvm it was the gas cap.
Old Jan 13, 2014 | 08:40 AM
hohmst1's Avatar
There is a TSB for this. It states that the PCM system needs to be updated. I recently took my car to the dealership to get timing belt serviced and it was $60 to have it done for me. Outdated PCM system causes vehicle to run lean. This may be your issue
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
ibGTV
Sep 28, 2015 03:40 AM
Billu99tl
Sep 13, 2015 11:30 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
