PLEASE HELP!!! I Two misfire codes now car won’t start but both fans come on
Subscribe
Jun 14, 2020 | 06:32 PM
I wanted to c if anyone could help me with a issue I’m have on my 07 type s. My check engine light started flashing n codes p0301 n p0306. So I tried to limp it home from work cause it was 5am n right before I got home there was a manhole cover I couldn’t c n I hit it. It wasn’t crazy hard hit drivers side wheel but after the is started to run a lot worse so I shut it off n replaced a 6 coil n plugs with brand new ones n now the car won’t start at all. Also my motor mounts r bad like u can c that there r split really bad. Also with I turn the ignition on both fans turn on n while I was trying to c if there was any codes the throttle body started clicking like crazy. Any info would be greatly appreciated also only codes before was p0420. Also when I turn the key to ACC both fans come on n the car has been sitting for 24hours. Also the temp gauge never got hot but was low on coolant due to that the radiator cap but I’ve replaced it n filled it with coolant. my buddy cane over with his snap-on scanner n it wouldn’t even read the car at all. Please help!!!
Reply 0
Jun 15, 2020 | 01:28 PM
I hate to tell you this but unless you’re a well seasoned tech I think this is definitely an issue for a shop to diagnose. Good luck with it
Reply 0
Subscribe
