both cooling fans won't shut off
Old Jan 10, 2017 | 08:08 AM
Blueback's Avatar
when my wife got home last night and shut off the car the cooling fans were running went in the house and came out an hour later and the fans were still running and the engine was cool. I disconnected the battery and this morning put the cable back on and both fans started running. What is the most likely problem? Possibly bad condenser fan and cooling fan relays?
Old Jan 10, 2017 | 08:22 AM
likely bad relays
Old Jan 13, 2017 | 10:02 PM
inACURATLy_accurate's Avatar
5th Gear
I've noticed a somewhat similar issue. Occasionally when I turn the car off the fans continue to run for about 5-10 minutes before turning off. However, if I start the car on and off, on and off, turn the key really hard, jiggle it around a bit, etc. the fans will turn off properly.
In my case it seems like a faulty ignition switch mechanism, but I'm not certain.
san Antonio tl
4G TL Problems & Fixes
Jan 11, 2022 09:12 PM
Cap'n Preshoot
Jul 7, 2021 10:05 PM
stevemk07
Jan 17, 2017 12:40 AM
TrackDayRdr
1/2G MDX (2001-2013)
Dec 20, 2016 01:33 PM
Jason Kain Pust
Dec 14, 2016 01:16 PM
