Missfire And Overheating!!! Help
Old Mar 21, 2010 | 11:56 AM
Importefx's Avatar
6th Gear
I have a 00 Acura TL I had a CEL for a oxygen sensor i replaced that everything was ok until about a week ago. My car overheats at idle "sometimes" and then when you put it in reverse it will act like it wants to stall out, you hit the gas and nothing happens then all of a sudden the car will jerk and start to go like normal.. This only happens when the car is cool not when it is hot.. I am out of ideas being that I do not have a CEL on now. Any help will be appreciated..
Old Mar 22, 2010 | 09:43 AM
Gil'sUA5's Avatar
just because u dont have a CEL doesnt mean u dont have codes so put the scan tool on it again... it could be something as simple as a coolant temp sensor or maybe u need a tune up
Old Mar 22, 2010 | 11:41 AM
NSXNEXT's Avatar
Coolant issue, you can check a few things
check coolant level
make sure radiator fan turns on when engine reaches operating temp - if not replace radiator fan switch
the stalling issue could be a myriad of things:
Idle speed incorrect
fuel filter clogged
faulty or incorrectly gapped spark plugs
vacuum leak at the thottle body, intake manifold or vacuum hoses
Old Mar 22, 2010 | 08:00 PM
Importefx's Avatar
6th Gear
I hooked up my scanner and no codes, i just did a tune up on the car,And the fan comes on only when the temo gauge hits the H before that it will not come on.... The car only acts like this once in a while and the car has to be cold for it to act up.... It is really pissing me off because it looses power then bangs into gear
Frathora
Sep 28, 2015 11:29 PM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
Jezek
Jun 20, 2006 11:30 PM
aRIff
Nov 9, 2004 12:12 PM
