Passenger side window doesnt go down
Old Mar 25, 2019 | 03:37 PM
mazen222's Avatar
So my passenger side window stopped reacting to the open button. I still hear a faded click, but it stayes closed. The issue was intermittent at first, now its permanent.
What are the potential issues? Do i need a new window motor? or the whole mechanism? is it better to open it, inspect and then assess?
Thanks!
MM
Old Mar 25, 2019 | 06:29 PM
window regulator is dead probably
of course it's the best solution to open and identify the root cause! Otherwise it's just throwing money at a potential non-problem.
Old Mar 25, 2019 | 06:41 PM
Midnight Mystery's Avatar
Null and proud of it
My 2008 was like this during my entire ownership. Wonder what it was.
We shall see, MM
Old Mar 26, 2019 | 01:37 AM
Will Y.'s Avatar
Registered but harmless
One thought: make sure the window lock switch is not on, and that the rear windows open and close before going further.
Old Mar 26, 2019 | 08:17 AM
mazen222's Avatar
It started working today... since its an intermittent problem i suspect its a contact issue.
Will Y. - Yes good point, i did the check to confirm.
Has anyone encountered this and solved it? I'd hate to open the door panel and rebuild it without fixing the issue.
Thanks!
MM
Old Mar 26, 2019 | 11:22 AM
Opening the panel isn't too tough, I'd do it just to examine the problem. It could also be something like a frayed/loose wire in the loom that goes between the door and the frame so you'll have to troubleshoot yourself.
dubz ASPEC
Jun 3, 2025 08:48 PM
RobE
Aug 28, 2018 08:14 AM
fedcrom
Mar 9, 2011 01:30 PM
arp408
May 14, 2009 02:09 PM
medicshane
Sep 11, 2003 10:50 AM
