Help: My passenger side mirror doesnt
Old May 12, 2009 | 09:50 PM
arp408's Avatar
fellas My passenger side mirrir doesnt move down anymore when I'm reversing. help!
Old May 12, 2009 | 09:58 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
if the mirror control is set on passenger side, then it wont move.
if thats not the issue, then its ur side mirror control unit
Old May 12, 2009 | 09:59 PM
MD03CL-S's Avatar
Is your switch to adjust your mirrors in the middle? If not, slide it between the L and R and try again.
Old May 12, 2009 | 10:18 PM
arp408's Avatar
Ohh no. I'm talking about when I'm reversing, my passenger side mirror automatically moves down so i can have a view of the pavement while backing up. But not it wont move down.
Old May 12, 2009 | 10:33 PM
VIPCLS's Avatar
P.
Well it should, make sure you have the mirror settiings in the middle on the control on the door.
Old May 12, 2009 | 10:47 PM
arp408's Avatar
I'll try that. But do you guys think its possible that my fuse is fried?
Old May 12, 2009 | 10:59 PM
aznboi2424's Avatar
if you can still move then mirror then its not a fuse. just put the switch in the middle and it will work.
Old May 14, 2009 | 10:48 AM
arp408's Avatar
It works haha. Thanks! MODS please lock!
Old May 14, 2009 | 02:09 PM
GreenMonster's Avatar
Yep, that's usually the deal... People hit the switch with their elbow and move it to the L or R position... it needs to be in the middle...
I've had it stop working on me before, and the switch WAS in the middle... Resetting the ECU did the trick... make sure you've got your radio code if you unhook the battery to reset... There's a fuse you can pull to reset the ecu too, but I forget where it is...Mr. Steve would probably know...
No need to lock the thread, someone else might need it later...
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
Oct 21, 2015 11:38 PM
sockr1
Oct 1, 2015 01:31 AM
