P0455 EVAP System Leak Detected
Old Aug 17, 2022 | 12:40 AM
TL_driverr's Avatar
DudeWithTheAcura
So I've replaced the gas cap, evap solenoid and vacuum lines with OEM ones, not cheap knock off brand.
this check engine light only happens when it is hot in the summer (does not happen in fall winter spring), so the fuel vapors are venting off and escaping I think? I would think there is a legitimate leak but I'm no expert.
Where else could this EVAP leak be coming from?
Old Aug 17, 2022 | 09:13 AM
twokexlv6coupe's Avatar
There's a million little vacuum hoses related to the EVAP system since there's so many solenoid valves; purge valve, tank vent valve, canister valve, etc.
The only way to pinpoint exactly where its leaking is by smoke testing the EVAP system. Will point you exactly to the leak.
Big Dom
Jun 3, 2019 03:22 PM
smartypants
Sep 22, 2012 04:41 PM
clavodulce16
Apr 3, 2008 05:13 PM
Chr8808
Feb 21, 2007 07:54 AM
joseph_99tl
Feb 12, 2006 04:45 PM
