evaporator canister
Subscribe
Feb 10, 2006 | 01:42 PM
i am replacing the evap canister.
can someone tell me if there is gas in these lines near the evap canister.
i'm thinking they would be just fumes.
i want to make sure that gas won't come running out when i disconnect these lines to the cansiter.
has anyone on this board replaced the evap cansiter?.
-joe
Reply 0
Feb 12, 2006 | 12:09 PM
Sound like you are replacing the Reciever/Drier. Why are you replacing that anyways? Is moisture getting into the system? The Reciever/Drier is Liquid filled located on the high side of the ac system. You cant replace that untill you have recover the refrigerant from the lines. ie: get the freon takin out of the whole ac unit.
Reply 0
Feb 12, 2006 | 12:57 PM
i replaced the 3 things.
so far no CEL.
there is a shoebox size canister right under the driver rear passenger.
i replaced that.
and some kind of electronic valve attached to the canister, and also a smaller canister that
also connects to the larger canister.
when i disconnected the first line...i could hear the gas tank bubble.
like i released some pressure.
but there was no fuel in these lines.
mostly gas vapors.
it's so nice driving without the CEL light on.
Reply 0
Feb 12, 2006 | 01:27 PM
Quote: Sound like you are replacing the Reciever/Drier. Why are you replacing that anyways? Is moisture getting into the system? The Reciever/Drier is Liquid filled located on the high side of the ac system. You cant replace that untill you have recover the refrigerant from the lines. ie: get the freon takin out of the whole ac unit.
i'm sorry.
not the A/C system.
emissions.
fuel tank vapor recovery.
Reply 0
Feb 12, 2006 | 04:45 PM
oooOO opps my bad...i thought it was the ac system since you mention evap (evaporator)
Reply 0
Subscribe
