P0141 ho2s b1 s2 heater circuit malfunction
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Confirmed DTCs : P0141 HO2S B1 S2 HEATER CIRCUIT MALFUNCTION
Car : 2005 Acura Tl 6spd Navi
I just need to confirm if I have the right part to order?
https://www.acurapartssource.com/acura-tl-parts.html
Year : 2005
Emission system
Emission components
rr oxygen sensor : $51.79 (Image 6)
Also how many o2 sensors are there?
1 on rear? 2 on front? Laf front? is that the one on top which is visible in front?
Sorry for all the question....
THANKS
Year : 2005
Emission system
Emission components
THANKS
Gents, I think it's a different part #....
B1 S2:
Bank 1, Sensor 2. Bank one is the side of the exhaust associated with cylinder 1, or the rear bank. Sensor 2 is the sensor after the cat (bottom or downstream sensor).
Part # 36542-RCA-A01
It's #13 in this diagram:
http://www.acurapartswarehouse.com/P...gPicture=False
I'd first reset the CEL and see if it comes back. Could just be a spurious signal. SM says to check fuse #19 in under hood fuse box and fuses #4 and #23 in under dash fuse box. If any one them are blown, it indicates a short somewhere in the sensor wiring harness. Troubleshooting procedure basically searches for shorts or opens and then to replace the sensor if no shorts/opens...
B1 S2:
Thanks nfnsquared that's the same part # I was thinking. It's weird I had a recall at dealer for p/s hose and after they did that I get this check engine light. I told them that the check engine light was not on prior they scanned it and came up with s2 bank1 permanent and s2 bank1 temporary codes :s
^^^ Here's an excerpt from the 8 page PS hose recall procedures:
![](http://i263.photobucket.com/albums/ii154/jmillerl/powersteeringhosetsb_o2sensor.jpg)
Jamus22
06-11-2023 10:08 AM
Biggie_B
02-26-2017 11:14 AM
