Overhead LED problem
Old Mar 19, 2013 | 10:19 PM
millatime84's Avatar
9th Gear
Hello all, new to the forum. I recently purchased a 07 white diamond type s. I though I would start off by switching out some lights with LED's. so far I've swapped the license plate / both front door lights / front overhead. My problem came when I inserted the rear 2 overhead LED. When I did so my front two began to pulse every second or so. Does any have any idea why this would be? Are the front and back the sme bulb?
Thanks in advance and I look forward to participating in this forum.
Old Mar 20, 2013 | 04:19 AM
felixthecat's Avatar
If by "sme bulb" you mean "same bulb", then yes, the front and back uses the same bulb. However, I never experienced your problem. You could try swapping the front and back LEDs and seeing if the problem persists.
Old Mar 20, 2013 | 07:04 AM
9th Gear
Hmm maybe I'm using the wrong replacement bulbs. I'm using the same as the doors and license plate?
Old Mar 20, 2013 | 09:08 PM
Yeah, doors, license plate, front dome, rear dome, vanity, and trunk share the same bulb. For LEDs, they'll be under type 194 or 168.
Old Mar 20, 2013 | 10:09 PM
9th Gear
I played with it again tonight and when I have the front 2 overhead with LED it works fine. When I put 1 LED in the Back and have 1 standard bulb it works fine. Its when I pull the final standard bulb that I have problems. This is what it looks like when I have all 4 LED installed or when I have only the front 2 install and no bulbs installed in the back.
Old Mar 20, 2013 | 10:13 PM
9th Gear
Note this video above is when none of light are on or the doors open.
Old Mar 20, 2013 | 10:43 PM
You mean if none of the lights are on AND the door is open?
Old Mar 21, 2013 | 06:45 AM
9th Gear
Sorry none of the lights are on and the doors are closed.
Old Mar 21, 2013 | 03:47 PM
By none of the lights being on, you mean none of the lights have been pressed, but the light switch in the center has been switched to ON mode, yes?
Old Mar 21, 2013 | 04:14 PM
9th Gear
yes, i'm in the car with none of the overhead lights on. I switch out the 4 light and that is what happens.
Old Mar 21, 2013 | 04:53 PM
This is my understanding of the matter.
1. You have your conventional lights installed. They are all off. The door is closed.
2. You start replacing them one by one with your LEDs that you bought.
3. Immediately, once the 4th one is installed, the front two start blinking like in the video?
Also, which setting are the lights on? ON-OFF-DOOR
Old Mar 21, 2013 | 09:00 PM
9th Gear
Correct and the 3rd led in back also flashes
Old Mar 21, 2013 | 11:41 PM
Which setting is the interior light switch on (ON-OFF-DOOR)?
Old Mar 23, 2013 | 09:37 PM
9th Gear
Active door
Old Mar 30, 2013 | 07:16 PM
Apologies for the mini thread revival, but I haven't had the time to hop on here.
If it's doing this on DOOR mode while the door is closed, then your MICU is acting up, since the LEDs will be regulated by the MICU. My question is whether you did the mods with the interior light fuse (fuse #6) pulled out or not? You can try restarting the MICU by disconnecting the battery for 20 seconds and triggering on the headlights to force any residual charge out of the system, but you'll have to let the car idle for about 10 minutes to allow the ECU to re-learn itself.
jblessing
Aug 8, 2018 09:43 PM
usual.acura
3G MDX (2014-2020)
14
Sep 19, 2015 05:01 PM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
brandnewcolony
Sep 12, 2015 10:39 AM
