Outside Temperature gauge
Old Feb 16, 2012 | 04:16 PM
trance957's Avatar
TL 08 Type S. the outside temp gauge displays "---" for 5-10 minutes every time I start the car, then the temp gauge works fine till the next start,
Is there a sensor or a relay that i can replace to fix it.
thanks
Old Feb 16, 2012 | 07:35 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
there is a tsb for this...
Old Feb 17, 2012 | 03:48 AM
trance957's Avatar
Any idea where i can find it?
Old Feb 17, 2012 | 05:31 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
go to the 3G garage. (stickied on the front page of the 3G forums). find the link to the TSBs, follow the directions exactly to access them. look through the list, there is one referring to the temp gauge (--). take a peek at it to find out what is causing it and how to fix it if it pertains to your car.
Old Feb 17, 2012 | 03:21 PM
trance957's Avatar
Cant find the link...
Old Feb 17, 2012 | 03:34 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
i looked at the TSB...apparently it only applies to early 2005's with navi.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
follow instructions on the link. leave all the new windows that open. go back to original page with the list of TSB's, then read away.
might be the same thing, just may not affect the later ones as much. or it's a completely different thing. sorry....not sure if i'm much help...but at least you'll know how to access the TSBs (i hope).
Old Feb 17, 2012 | 06:37 PM
trance957's Avatar
Got it thanks.
But still dont know how to fix it.
Old Feb 17, 2012 | 06:41 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
dealer?
Old Feb 17, 2012 | 09:22 PM
usmarinedelta's Avatar
The sensor is right under the front bumper support frame. If you stick you hand on the right side under the front grille you can feel it. It's held on by a clip. I beleive the part isn't that expensive.
Old Feb 21, 2012 | 05:04 PM
trance957's Avatar
Picked up the Temp Gauge today, install tomorrow, and will report
Old Feb 29, 2012 | 02:52 AM
trance957's Avatar
Been driving the car for a week now, takes between 3-5 minutes, before it shows the temp. is this normal?
Old Feb 29, 2012 | 05:58 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
It should pop up when you start the car.
Old Feb 29, 2012 | 11:40 AM
Will Y.'s Avatar
Registered but harmless
A temp number will appear when the car is started, but it may not be the correct temp, per the owner's manual.
The sensor takes 3-5 minutes to adjust and read the proper outside ambient temp.
Are you still getting "---" before the numbers show up?
If so, it should be repaired under warranty.
If the car is not under warranty, I'd probably leave it alone since the proper temp shows up after the proper time.
Old Feb 29, 2012 | 04:27 PM
trance957's Avatar
Car got 72000 miles, so its not under warranty. I wonder what cause it
Old Feb 29, 2012 | 09:38 PM
Will Y.'s Avatar
Bummer.
The 2005 TSB indicated replacement of the "Gauge Control Module" was necessary after disassembling the instrument panel, so I wouldn't mess with it if the temp is correct after a few minutes of blank reading.
Old Mar 16, 2012 | 04:33 PM
trance957's Avatar
Update, my car is back to 30 minutes before the gauge start working, which means the climate control wont work till the gauge show some numbers.
Idea's!!!
Old Mar 17, 2012 | 03:01 PM
mindanaomoro's Avatar
I was able to reset mine by pulling the #7 fuse under the driver side foot panel area.
Old Mar 18, 2012 | 04:06 PM
trance957's Avatar
Ill do that tomorrow AM.
Old Mar 23, 2012 | 02:25 AM
trance957's Avatar
Three Days in a Row, working fine like nothing wrong
Old Mar 23, 2012 | 05:41 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
Old Mar 23, 2012 | 03:13 PM
trance957's Avatar
Why would it work, had to wait 10 minutes for the AC to come on,
Old Mar 23, 2012 | 05:16 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
you jinxed it.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
